Question about Laser Jet P3005d Printer
Recent I have installed hp laser jet p3005d and was working fine for some timebut now i get a problem that when u power on the printer the printer starts to boot and after some seconds stops and there is no information on the dispaly excep simple light.so can some one any idea how to fix the problem. Thanks
1 Related Answer
Anonymous
  • 28 Answers
SOURCE: recent I have installed hp laser jet p3005d and
Yes! Of course Printers are the most difficult machinery in the hardware world. Just turn of your printer restart your computer and now once you reeboot your printer and computer it should be able to recognize your devices your printer once that happens just respond back to me Ok!
Posted on Mar 26, 2010
HP COLOR LASER JET 2605 PRINTER 49 ERROR MSG DISPLAY SOLUTION
49 errors are most commonly caused when the printer receives a print job with commands it does not recognize. You can try updating the firmware as this will often resolve the error. Go to HP's website to find the most recent firmware, however this model is fairly old and likely the firmware update will be fairly old.
Sep 25, 2014 | HP Laserjet 2605dn Workgroup Laser Printer
How to use duplex printing ?
You must make sure that in the device settings of the driver for the printer that it shows that the printer has a duplex option installed. Then when you go to print, select properties and output and select 2 sided
Sep 24, 2014 | HP LaserJet P3005d Q7813A Laser Printer...
I m facing problem hp laserjet 3005n 59.50 error
59.50 ERROR
alternates with
To continue turn off then on
A main motor (M1) error has occurred. Motor
operation is verified during device power-up.
1. Turn the device off and then on.
2. Verify that nothing is hindering the main
motor. If necessary, remove all paper
trays and the print cartridge, and then
turn on the device and listen for motor
operation.
3. Verify that the main motor is connected
to connector J407 on the ECU. (See
Figure 6-9 ECU wiring on page 195.)
You might have to remove the main
cooling fan to see this connection.
4. If the message persists, replace the
motor.
Part #
RK2-1488 Main Motor
Dec 31, 2010 | Laser Jet P3005d Printer
I can not find a HP color Laser Jet 1600 driver in my computer to set it for printing. Can you help me down load the HP Color Laser Jet 1600 driver to set my printer up?
You need to download the printer drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Click on this link to download the drivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Sep 06, 2010 | HP LaserJet 1000 Printer
Error code 81.0180 eio 1
upgrade the firmwere of jet direct card your problem will be resolved
Aug 31, 2010 | HP LaserJet P3005D Monochrome Laser 35...
Recent I have installed hp laser jet p3005d and was working fine for some time,but now i get a problem that when u power on the printer the printer starts to boot and after some seconds stops and there is...
Mar 26, 2010 | Laser Jet P3005d Printer
I'M GETTING A 59.50 ERROR ON HP LASERJET P3005d. HELP
59.50 indicates a main motor failure either the motor is bad or something is stopping it from turning. can be as simple as a bad toner.
turn the machine on and listen for the motor noise if you don't hear it turn the machine off remove the toner and turn it back on if you can hear the motor running youmay just have a bad cart.
hope this helps
Jan 21, 2009 | Laser Jet P3005d Printer
Color Laserjet printer
yes.u can buy hp2600.its recent .its very user friendly.u can go for it.
Dec 11, 2008 | HP LaserJet 4700 Printer
Laser Jet P3005d Printer Logo
Top Laser Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Barbat Nae
Barbat Nae
Scott Kalvinek
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
