Question about Mitsubishi WS-55511 55" Rear Projection Television
Power button bilinking
Rearrange my furniture in the livingroom. Move tv from one wall to another. Unplug the cord and plug it back in, power button just blinking. Tried reset button, unplugged for a few hours, still it's not working. Check all the plugs in the back panel and push them in thinking that maybe one of the cord is loose. Still no luck...
Posted by rdeejay73 on
    Top Expert:
  • Mitsubishi Master
  • 76,407 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Nov 09, 2017
5 Related Answers
TVtechmaniac
David Makowski
  • 140 Answers
SOURCE: won't power up
This model has had problems with the keyboard buttons on the front panel,causing them not to work and canceling out the remote operation. To verify this,you need to remove the front panel so you can access the connector on the keyboard pc board and unplug the connector.After doing this,see if the remote control is able to turn on the tv (wait for it to power up because with the connector off, the green power light will be disconnected and will not light up when the tv is on) If the tv works, than you will need to change the ten individual switches on the board - part# 432P089010 (or just use the remote only)
Posted on Aug 21, 2007
Anonymous
SOURCE: Mitsubishi TV WS 65869 blinking Green Light
This is a common problem with Mitsubishi rear-projection TV's.
See my post at http://www.highdefforum.com/showthread.php?t=58189
or email me at [email protected]. I can send you the instructions I used to successfully repair my Mitsubishi WS-55613 which was doing the same thing....
Posted on Dec 08, 2007
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Posted on Dec 15, 2007
Anonymous
  • 5 Answers
SOURCE: WS-55909 Mitsubishi Big Screen TV timer keeps blinking
it must be recording soething have u got IQ?
Posted on Dec 30, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Model WS-55909 Green light flashes won't go out. No TV
You need the WS55909 - WS73909 DM kit. You can get it at the following link which contains the capacitors and the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
Posted on Jul 18, 2009
I have a 2 control mattress heater. One side works fine but the other will show a f error when put on preheat
Unplug the power cord from the wall outlet. Check that the control is tightly connected to the module in the blanket. Re-plug the power cord into the wall outlet. On a digital control, you should see flashing symbols and the display on your control will clear.
Jan 03, 2018 | Furniture
HOW TO SOLVE PRINTER ERROR WITH BLINKING LIGHTS
Unplug the power cord from the all-in-one.
Wait 30 seconds and plug the power cord back into the wall outlet.
Press the Cancel and Right Arrow buttons.
While still holding the buttons, plug the power cord back into the all-in-one. Continue to hold the buttons for two seconds, and then release them.
Use the On button to turn the power off and then back on again.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Jan 30, 2013 | Epson Stylus Photo Px660
My 32inch lcd tv keeps flickering it started all the sudden
TRY THIS
    • 1 Turn the TV off with the front-mounted power button, not the remote. Unplug the TV's power cord from the wall outlet. Let an hour pass before plugging the cord back into the wall outlet. Turn the TV back on with the front-mounted power button and wait until it has fully restarted. Bring up a TV channel to see if the image being presented on the LCD screen is no longer flickering. A momentary power surge can cause the circuitry inside the LG-brand LCD TV to function erratically.
    • 2 Unplug the video cable from the video connection on the back or side panel of the LG TV. If more than one video cable is connected to the TV, disconnect all of them. Disconnect the other end of the video cable from the video source device that it's attached to -- a DVD or Blu-ray player, or a satellite receiver or cable box. Blow off the connections on the video source device and on the back or side panel of the TV with bursts of compressed air. Reinsert one end of the video cable into the video source device and the other end into the video input that it was connected to. Turn the TV back on with is remote to see if the picture is now free of flickering. A loose or partially connected video cable can cause the LCD TV's screen to flicker when presenting an image.
    • 3 Turn the TV off and unplug its power cord from the wall outlet. Place a power conditioner next to the wall outlet. Plug the power conditioner's power cord into the wall outlet. Plug the TV's power cord into one of the AC sockets on the power conditioner. Turn the power conditioner on. Turn the TV on to see if the picture is now free of flickering. The RF signals in the electric line that the LG TV is drawing power from can cause flicking through interference patterns being generated.
Oct 20, 2012 | Computers & Internet
HP 5510v all in one is froze. In the led box it keeps blinking error:oxfoaf8004 Have tried unplugging & plugging several times, popped open cartridge door and had to manually move cartridges,...
  • unplug the power cord from the back of the printer and from the wall outlet
  • hold down the power button for a minute to drain power
  • plug the power cord back in to the wall
  • press # and 3 on the keypad while plugging in the power cord to the back of the printer
  • let go of the keys when the printer starts up
Jul 29, 2011 | HP Officejet 5610 All-In-One InkJet...
Hp officejet 6500 all lights are flashing and mechine says turn off and on . Please can someone Help??
: Check the power cord
1.
Turn on the product.
2.
Remove the power cord from the back of the product.
3.
Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
If these steps resolved the issue , you do not need to continue troubleshooting.
If the issue persists , continue to the next solution.
Turn the product off and then on again
1.
Press the Power button ( ) to turn the product off.
2.
Wait 60 seconds, and then press the Power button ( ) to turn the product back on.
3.
If the product does not turn off when the Power button ( ) is pressed, wait three minutes, and then proceed to the next solution.
Plug the product into a wall outlet
Follow these steps to make sure the product is plugged in correctly.
1.
Unplug the power cord from the back of the product.
2.
Unplug the power cord from any surge protectors or power strips.
3.
Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4.
Plug the power cord into the back of the product.
5.
Plug the power cord into the wall outlet.
6.
Press the Power button ( ) to turn the product on.
Solution six: Reset the product
Follow these steps to reset the printer.
1.
2.
3.
Wait 10 seconds, and then plug the power cord back into the wall outlet.
4.
NOTE: Many power cords have an LED light on the power module or on the end of the cord that plugs into the product. Make sure the LED light is lit and steady.
5.
6. Perform a partial reset of the product
  1. Disconnect the power cord from the product.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while reconnecting the power cord.
  4. When the product turns on, release both buttons.
  5. Try printing again.
IF still won't resolve it by following steps mentioned above then your printer needs replacement. Malfunctioning hardware.
Mar 28, 2011 | HP Officejet 6500 Wireless All-in-One...
My display screen is rolling and nothing stops it. My computer says the printer is offline.
Try doing this procedure to correct the problem.
1. Unplug the power cord from the back of the product.
2. Unplug the power cord from any surge protectors or power strips.
3. Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4. Plug the power cord into the back of the product.
5. Plug the power cord into the wall outlet.
6. Press the Power button to turn the product on.
7.Now check if its already working.
May 16, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Psc 2210 sounds like the gears just keep grinding then after a bit it stops. says press enter and nothing happens.
perform power cycle
1. Unplug the unit’s power cord from the back of the printer while the printer is 'on'.
2. Hold down the ‘On’ button for 60 seconds
3. Plug the power cord back to the unit while holding the ‘On‘ button down.
4. This will reset the printer’s mechanical systems and discharge all capacitors.
If the issue still persists, then
  1. Unplug the power cord from the wall outlet.
  2. Unplug the power cord from the all-in-one.
  3. Wait 30 seconds, and plug the power cord back into the wall outlet.
  4. Press and hold the # and 6 buttons on the numeric keypad.
  5. While still holding the buttons, plug the power cord back in to the all-in-one. Continue to hold the buttons for two seconds, and then release them.
This should resolve your issue.
Sep 02, 2009 | HP PSC 2210 All-In-One InkJet Printer
Zvonko jelusic from belgrade
The print carriage is stuck.
Solution
  1. Open the top access door on the printer.
  2. Remove the print cartridges.
  3. Close the print cartridge flaps after removing the print cartridges.
  4. Turn the printer off and then on again.
  5. Replace the print cartridges.
  6. Close the top access door.
If the resume light continues to blink after the print cartridges are released,
OR
the print carriage is stuck or makes a grinding noise, follow these steps.
Solution
  1. Lift the top cover to the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cord from the back of the printer when the grinding noise starts. Unplug the power cord from the wall outlet.
  4. Move the print carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
  5. Take out the print cartridges and close the top cover.
  6. Plug the power cord into the wall outlet. Plug the power cord into the back of the printer.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover
Solution
  1. Open the top cover.
  2. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet. Wait a minute or so.
  3. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 22, 2008 | HP DeskJet 5550 InkJet Printer
No picture, no sound, power light steady green
First: Check the power outlet. Check it with a good lamp so you know you are getting power to the set.
Secondly: Check the power cord. Wiggle it around the molded ends to make sure it is not open inside the molded portion of the plugs.
Thirdly: If you know for sure the set is getting power and still no indication at all (you should be getting some little light on the front panel; standby indication) then there may be a fuse on the back panel or just inside the back cover (you will have to remove it; after unplugging the power cord) that needs replaced.
Fourthly: After all these checks if you are getting nothing, you may have some failure inside that is very serious. Normally we do not recommend serious repairs to a set over 4 years of age. This is because the set is likely to develop some other problem soon after the repair is made; further, the repairs are getting more expensive day by day while the price of new sets is coming down dramatically. Lastly, the new sets have better picture, longer lasting circuits and better features.
Hope this is a good solution for you.
thanks for your questions.
Aug 25, 2008 | RCA HD52W56 52" Rear Projection HDTV
Hp c7280 all-in-one printer will not shut off
I'm assuming your printer power button will not shut the printer off. You can unplug the power connector from behind the printer if it won't shut off via the power button or power switch.
Performing a power reset
  1. Press the On button to turn off the HP All-in-One.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Unplug the power adapter from the wall outlet and wait for 30 seconds.
  4. Plug the power adapter back into the wall outlet.
  5. Plug the power cord to the back of the HP All-in-One.
  6. Press the On button to turn on the HP All-in-One.
Apr 20, 2008 | Office Equipment & Supplies
Mitsubishi WS-55511 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
