Lower for legs there should be a drain bolt for each leg do one side at a time.
Take the top fork cap off be careful the top cap is spring loaded get a pan to catch the oil,remove the drain bolt let it drain.reolace the drain bolt then you can add your new fork oil,check your owners manual for the proper amount and weight oil you need to replace, replace the fork cap.
repeat steps on the other fork.
SOURCE: how much 5w oil goes into each fork?
Using 5w oil with stock springs, your oil level should be about 100mm from the top with the fork fully compressed, damper rod pushed all the way down, and the spring out. I hope this helps and good luck. Please vote and leave a message.
SOURCE: Need to change fork seals on xr400
http://www.carlsalter.com/motorcycle-manuals.asp
free pdf service manual here
SOURCE: harley davidson flstc heritage softail 1997
The fork oil is a very specific job needing a manual and a special tool, I don't want to insult anyones mechanical knowledge but if you have never done it before, best to take somewhere else. Engine oil on the other hand is easy, the drain tube to any softail is on the right side by where the frame meets the swing arm, has somekind of plug in it. Start and run bike for a little while, long enough to get it warm but not hot. Remove fill plug and then remove plug in drain line. Using a peice of cardboard or something put in between filter and frame , directing the oil to your drain pan instead of where ever it goes. Put 1 qt oil back in (after everything is reinstalled) start the bike and make sure the oil light goes out, when it does shut bike off and fill to the point that when it is standing upright you get a little oil on the tip of your finger, over filling may result in loss of oil cap from pressure (been there)
