1996 Pontiac Sunfire Logo
Posted on May 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Front wheel bearings bad
Does this front wheel drive have wheel bearigs in front? I have a loud humming noise which gets louder when I turn the steering wheel.
(1996 Pontiac Sunfire)
Anonymous
Level 2:
  • Expert 72 Answers
  • Posted on May 05, 2010
Anonymous
Expert
Level 2:
Answers
72
Questions
0
Helped
33187
Points
244
If it gets louder when you turn left then the right front wheel bearing is bad and vice versa it gets louder when the weight shifts to that wheel
MY 1998 FOR EXPLOYER ELT HAS A LOUD HUMMING NOISE THE FAST I GO THE LOUDER IT GETS CAN ANY ONE TELL WHAT A POSSIBLY CAN BE .MY HUSBAND SAYS THE SPINDLE????
Humming Noise Front End- Any Ideas? - Ford Explorer and Ranger ...
www.explorerforum.com > ... > Stock 1995 - 2001 Explorers
Dec 18, 2008 - 19 posts - ‎16 authors
Have a 98- Eddie 4.0 SOHC, 4WD with a 100,000 mi. When driving it has a humming noise, it almost sounds like a bad tire, or a ... I start to hear the humming noise at 20 mph, it is very loud at 40 to 50 mph ... 94 XLT-95 FX4. humming gets louder as speed increases
May 27, 2010
How to: IAC valve cleaning thread (w/pics)
Oct 29, 2007
humming from air intake
Jun 6, 2002
Loud humming noise coming from the air filter
Oct 6, 1999
More results from www.explorerforum.com
Humming noise wheel
Sounds like you replaced the front bearing. Could be a rear wheel bearing, or one of the tires.
Constant loud humming from front of hyundai gets
If the noise get louder as you speed up, it is possibly a wheel bearing, needs checking out by a mechanic.
Loud humming noise front end moving
While driving, slightly turn the wheel left and right, to see if the noise gets louder and quieter. If it does, you have a wheel bearing that is failing. Then you need to isolate which side is making noise and have it replaced. SOON
1996 ford contour loud humming noise and vibration from front wheels
You have a defective wheel bearing most likely, the noise sounds correct for that problem. have a shop drive it before you replace anything to confirm my guess.
2answers
1helpful
I just bought an2003 ford explorer 4x4 and i have a loud humming noise coming from the front end tires are brand new it has around 190,000km please help
If the noise is only when the vehicle is moving it sounds lek you have a bad wheel bearing. You can inspect ford move ment or play shaking the tires up and down and left to right while lifted up on hoist or jack. If there is no movement doesn't necesarily mean the bearings are okay, however if there is movement in bearing replace and drive again. Antoher way to determine Which wheel bearing is bad is to drive and turn to the left, if the noise gets louder than it mens the rightside wheel bearung is bad. If you turn to the right and noise gets louder replace driver side front wheel bearing. Also Rub your hands across your tires, does it feel wavy or uneven, you could have cupped tires, I DON'T KNOW HOW NEW THEY are but cupped tires will also make this noise. One way to see if it is the tires is to do a rotate If noise changes at all then you no its a tire causing noise. Hope this helps.
10helpful
3answers
The car makes a howling noise while driving it
well did the noise start after the tires were rotated?could be choppy tires,,,if not ,i strongly think it sounds like a bad wheel bearing,,,,if you drive and while its making the noise turn left and right quick and see if the noise gets louder and which way turning makes it louder,,if you turn leftand it gets louder its usually the right wheels bearing as you are putting load on it, if it makes the noise louder while turning right its the left wheel bearing,,,got it
Is this rumbling wheel bearings or transmission?
If the sound is all the time, no matter what you are doing then it is the Transmission going bad. CV Joints, Wheel bearing will only make the noise when in rotation.. Also remember that this is a front wheel drive car, so it will throw you off thinking it is the wheel bearings or CV joints due to the front wheel drive
Alero loud humming/roaring sound coming from front end.
That's indicative of a wheel bearing, which is why you were told to change that out. However, it's also possible that the carrier bearings in the differential (where the drive axles attach) have gone bad. That happened to me on my 300ZX several years ago, and I had to replace the diff bearings. I would have them checked out somewhere other than a dealer (you'll probably get a better price from an independent shop).
As a sidenote, to be sure it wasn't a wheel bearing, if you hear it quiet down in a turn one way but get louder in a turn the opposite way, it's likely the wheel bearing. If you turn left at speed and it gets louder, then it's the right bearing (since you're loading up that side of the car). If it gets quieter in a right turn, it's the right side (you're unloading that side of the car and not putting as much weight on it, so it doesn't drag as badly). See if you get that symptom just to be sure that the wrong side front wheel bearing wasn't changed.
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
