We just bought a used Maytag bottom freezer and it was working perfectly for about 2 weeks. Everything was frozen. Now today the freezer isn't pumping ice cold air. The ice cubes are still frozen, but ice cream and bread have completely thawed. These items are on the top shelf and near the opening of the door. But the door is air locked tight.
What could be the problem?
SOURCE: Maytag MFD2561HEQ Bottom Freezer Refrigerator - Freezer working, refrigerator not
Marc of Nc. check to make sure the fan in the freezer is operating when the compressor is on. The only thing the fresh food section gets its cool air from is the freezer. and if the fan is not operating no cold air will get up there. If the fan is running you need to make sure the air duct is not blocked with frost of the evaporator is not iced up. Check that out and get back with me if there still is a problem. Good Luck
SOURCE: We have a Whirlpool gb22dk
1st.Check the freezer door gasket for any place it maybe torn or not making a 100% seal when you close the door.That would make temperature drop. 2nd.take off bottom kick plate so you can look under the refrigerator.Using a flashlight make sure there is not alot of lint / dust stuck on the coils .If there is remove it carefully and you will see temperature lower. PLEAS RATE THIS!
SOURCE: Top freezer food gets freezer burn fast and now ice cubes and ice
Your discribing 2 opposite symptoms. But 1 thing may be causing both. first thing I think of is a defective defrost heater safety switch. It allowes the food -and freezer compartment to become too warm during defrost. This allowes the food to un freeze. then when defrost is terminated the temp goes back under freezing til the next defrost. 3 to 5 cycles like this and yes you could ahve freezer burn and icecream melting. DOes the ice cream refreeze too? If so you have to remove the freezer pannel covering the evaporastor coil inside the freezer. Locate the defrost safety.
1 of 3 kinds 2 opf these are b8-metal switches and are round and of these 2 kinds 1 is about nickel size and the other is about quarter size and both are round and can be attached to the coil tubing or the freezer wall. Usually these 2 kinds are on Refg/Freezers with no electronics on the door or thermostat.
If you have an Led or LCD display you ahve electronic controls and in most cases have an electronic thermisitor about 1" long and 1/4 to 3/8 inch dia and insulated and attached to the freezer coil line leaving the freezer or on one of the U bends of the coil. It may be attached with a plastic wire tie. (The tie could be broken but this is doubtful from discription).
1st freezer burn is usually caused by drying out of the food while still frozen. And this is why your case is so interesting by doing it so quickly. In all cases 1 the food is not in air tight containers. And the water in the food is being drawn out of it.
SOURCE: Ice cream and bread don't freeze, food in frig DOES freeze
Not fixed but I do not want to spend MORE money to find out what's wrong with this AMANA piece of ****. Apparently, from research on the net, the compressor or motor is not strong enough in this unit to actually do the job...but if anyone has any suggestions, I'm happy to hear them...
SOURCE: bottom freezer on Subzero refrigerator not thoroughly freezing
the aspiring air in the freezer botton don't work... sorry for english, i am french...t k
