This sounds like a bad door switch,if you replace the switch i think it will solve all these problems,the switch is locted on the latch asm,remove the door panel,mark and remove the linkage,then unplug connectors,then remove screws holding latch,remove the latch and then remove switch,it comes out by twisting,and then pull up,to install new one,line up slots push in and turn to lock in place,good luck.
