When I plug my HDMI cable in, it doesn't seem to work anymore. My TV would say that there is no source, but when I turn on the DVD player, the box that says that goes away but no picture shows up. It used to do this just fine. The HDMI cable is good because it also works well on my Xbox 360. How do I get it to make the HDMI work again?
SOURCE: Magnavox MWD200F not working anymore!!!
since you have plugged out the DVD for 3hrs the conclusion is that you will need to take it to a repairman the problem with your DVD is that it got a surge due to the power failure.that sound you are getting is from the little transformer in the power supply,the current stops at the primary windings and is not crossing over the the secondary winding to complete the cycle.good luck i was the one who told you to plug it out for 3hrs
SOURCE: connecting LG DVD recorder to cable box and HGTV digitally
Two things come to mind: copy protection and resolution settings.
The TV may not allow copy protected material to come from your LG, or the sampling frequency may be unacceptable. On page 15 of the manual it talks about 96kHz and 48kHz frequency settings. The third thing to check is the vertical resolution using the RES button on the front panel. SDTV is 480, and HDTV is anything above that. Using the HDMI is supposed to allow upconvert to 1080i max if your set can use that resolution.
tom
SOURCE: Distorted color on hdmi output
If you haven't already stumbled across the fix: I just had the exact same problem after about eights months of casual use. Unplugging the DVD player for about 15 minutes and then plugging it back in "solved" the problem. Until next time it happens, anyway.
"cable box to tv is hdmi cable"
Everything I've read on the web says cable box to tv connection must also use component (rgb) cables. The error is coming from the cable box (STB). All the Scientific Atlanta (SA) cable boxes seem have this Digital Rights Management (DRM) bug and the only way to be totally rid of the error is to replace the digital connection from box to the TV with an analog connection.
SOURCE: No Picture on HDMI using Philips DVP5992.
You can try out by connecting the CVBS (Yello) out from player to TV and connect HDMI out from Player to TV. Goto CVBS input on Sony TV. Select set up and you should get the HDMI Video options availble. Try to change the resulution and check for Video on HDMI source.
Which disc you were playing PAL or NTSC? PAL should work for Europe.
