I put it on the canon 5d mark II, I just bought and I was taking some test shots, when I looked at the pictures in the lcd, the flash fired like a strobe for a second, it did this a few more times for no reason, It did this when i had it on av,tv,p,and auto mode, I got a new flash and did the same thing so now I thing it's the camera. Anybody have this problem??
This depends on the mode you have selected on the flash gun. If you have Multi selected you will get the strobe effect. The strobe effect is all so present to help the flash set the correct exposure. It's not a problem with the flash or the camera. Spend some time reading through the flash gun manual. I have to admit it is not always clear. Also try Youtube for a video.
SOURCE: I mounted the Canon 580EX II to my Canon 5D Mark
Yes. If you were able to set a faster shutter speed, then you would not expose the entire frame and would have the shadow of either the first or second shutter curtain (or both) partially masking the frame.
At higher speeds, the shutter is never fully exposed: before the first shutter curtain has finished travelling across the frame, the second one has stated it's journey. All SLR's have this issue and on some older models you could only use a maximum 1/60th of a second.
In practice though, in dark conditions the "slow" shutter speed does not affect exposure as the true exposure will be determined by how much light the flash puts out, and it puts this light out in as little as 50 microseconds (50 millionths of a second) for a modern electronic flash bulb.
Faster shutter speeds can be used successfully, but only with flashes which operate in high speed mode. What they do is to make the flash burst seem longer by rapidly firing the flash bulb many times. This trick can ensure that there is sufficient light to expose the frame at the highest shutter speeds. Shutters which operate at, say, 1/4000 may seem fast, but compared to the speed at which a single electronic flash burst operates, it's an eternity.
