Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Bad smell that won't go away
Hello. Had some fish in the fridge for only 2 days, didn't go bad, didn't leak out. But now I've had a lingering fish odor for 3 weeks. Pulled everything out and cleaned thoroughly, twice, boxes of baking soda, etc. Now smell is in the freezer as well. Is there any filters I'm missing? It is a 10-15 year old Amana side by side that has performed very well. Help!
Posted by djrudisill on
STEVE yes that one
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Amana Master
  • 35,496 Answers
Try a bowl of white vinegar for a week or so. m just dont spill it!!
Posted on Sep 21, 2017
5 Related Answers
Anonymous
  • 159 Answers
SOURCE: refrigerator will not get cold, but freezer works
Do you know if the compressor in the back is running? If you can check that out get back to me and we can go from there. Most times if the fan in the freezer is running the defrost timer is ok.
Posted on Jul 12, 2007
MARK FISHER
  • 87 Answers
SOURCE: Refrigerator Smell
Is the problem more in the freezer than the fridge section. If it is it is possible that on a defrost cycle the heaters which warm the coil may have warped and ar heating something they shouldnt. Another possibility is if there is something in the condensate tray (where the water collects) or something touching the compressor which runs very hot, or even the compressor relay if it is a 'plastic' smell. Smells are notoriously bad things to trace as engineers normally turn up when the smell is either gone or so faint as to not to detect. All I can suggest is trying to narrow the search area as much as you can and hopefully youll find it. Hope this is of some help.
Posted on Sep 15, 2007
Master_Tech
Gary Davd
  • 770 Answers
SOURCE: chemical odor...
Is the unit working ok I think tech17 is trying to find out if you have a freon leak inside the unit??
Posted on Jan 27, 2008
docjohn174
john gagnon
  • 943 Answers
SOURCE: Amana bottom drawer fridge/freezer combo
hi. thanks for the question . it sounds like you have a compressor problem . wich is under warranty from amana. great news get in touch with amana thanks the appliance doc
Posted on Sep 28, 2008
Anonymous
SOURCE: odor in fridge
Probably getting a new Fridge-mother doesn't want to continue to deal with repairs. Thanks anyway.
Posted on Oct 13, 2008
Very bad smell coming from my Samsung refrigerator
most refrigerators have a small drainage hole leading from the inside rear of the compartment to an overflow container behind the unit, pull the unit away from the wall and check if the liquid in the container has become stagnant, if so simply clean it out and run a small amount of bleach down the hole to disinfect the tube.
hope this helps.
Nov 11, 2013 | Samsung RS261MDWP - 26 cu. ft. Side by...
Freon leak in refrigerator?
no refrigerant leaks have little to no odor and if it was leaking bad enough to smell it the unit would be out of refrigerant and not cooling...the problem sounds like gases coming off of a veggie of something un-covered inside the fridge--have you put any veggies in the fridge or freezer un-covered check real good if one or a piece of something has fallen behind something else where you cannot see...all else fails remove all your products from the unit and clean and get a box of odor control arm&hammer to rid the smell..as for a leak in the sealed system i think your just fine.
Mar 27, 2012 | Samsung RF265AA Bottom Freezer French Door...
Help. I shut down my refrigerator when I moved. When I opened the door, I found the refrigerator full of maggots. I used clorox to clean it but I heard there could be eggs that I could not reach. Is...
Maggots are the larvae that have hatched from insect eggs. Yes, there might be eggs somewhere still in your refrigerator. I would suggest that you locate an insecticide (a bomb type perhaps) and set it off in your refrigerator BUT UNPLUG THE REFRIGERATOR FIRST. Close the doors and let the refrigerator stand for a week. After that time, you will need to carefully wipe down all surfaces with a mild soap solutions. Then rinse well. If there are still lingering odors you can wipe again with baking soda solution or you can place activated charcoal in the refrigerator to absorb the pesticide odor. I had this same thing happen in a foods lab with a microwave oven. I used this procedure and never had maggots again. You don't have to be a dirty person to have problems like these! I hope this helps. If it does, please come back to Fixya and rate my advice!
Jul 28, 2011 | Refrigerators
The fridge and freezer smell like a dead animal. cleaned the inside with bleach but still smells for weeks. model w10212088
There are two reasons for bad smells. 1. Long time not being used. 2. Lack of cleaning inside compartment.
Solution: Unplug fridge. Keep open fridge door. Dip a dry cloth in soap water and start cleaning each and every compartment. Keep freezer door also open. And then clean with another dry cloth. Keep both doors open for nearly 5 hrs. It will be enable fresh air to **** the smell inside fridge.
After 5 hrs close the fridge and run on empty for one hour. Keep food items after one hour. Please keep all food items closed vessel. Not only it's avoid odor but also be hygienic.
If you use to keep fish items in freezer, clean fridge once in a week.(Spray roo spray in the room when you keep fridge door opened. Don't spray into fridge.)Helpful.
Jan 30, 2011 | Whirlpool Refrigerators
Foul fish smell emanating from the freezer
Well an old remedy is to put a box of opened arm and hammer baking soda in the freezer and fridge to keep it from having bad odors.If that doesn't work you can try some charcoal it is perfect for absorbing odor, just don't use the matchlight kind or it will smell like lighter fluid.
Apr 06, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
I have an oder in my fridge and freezer. no spoilage in there. both the fridge and freezer has an odor and gets into all the food. cleaned it out, shut it off for a day and still i have it. would would...
ok.its a very common issue.just tie a handful of baking soda in a soft cloth and keep such1 or 2 pads in both the freezer and fridge section.this will absorb all the bad odor within a day or two.once the odor is gone throw the pas away.repeat this once in three months to prevent the bad odor from coming again.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 28, 2010 | Amana ABB1927DE Bottom Freezer...
My new Whirlpool Refrigerator the water and ice still stink
We have the same problem. Started 2 weeks after purchase. (6 months ago). Tech. replaced fliter, worked for another 2 weeks, then water & ice awful again. Tried to live w/ it - ordered another filter a week ago. Replaced & within 24 hrs. problem was back. Called Whirlpool. Said tech who came to my househad written in his report that tap water & fridge water tasted the same. A lie - he agreed w/ me that the water from fridge was bad, & replaced filter which had a musty odor. Whirlpool basically called me a liar but agreed to send another tech to check it out. I will never buy another Whirlpool product & plan to tak this problem as far as I need to in order to get satisfaction. This is ridiculous!
Dec 19, 2008 | Whirlpool Refrigerators
Smell
A product that we used earlier made by a small company in Florida has unfortunately disappeared from the market and we have looked for a replacement for a long time.
You problem brought me to look again and I found this:
http://www.amazon.com/review/product/B000LNWDEM/ref=dp_top_cm_cr_acr_txt?%5Fencoding=UTF8&showViewpoints=1
We will order it but I can't recommend it yet.
The other stuff was sold in drug stores in little bottles and really had nearly no odor of its own but instantly killed every odor we ever wanted to lose.
Jul 14, 2008 | KitchenAid Superba Architect KSCS25INSS...
Smelly Fridge
Try putting an open can or two of coffee inside. My mother's freezer had gotten unpluged and it was full of fish. She put cans of coffee inside and shut the door a couple of days later she took them out and the freezer did not stink anymore. Hope it works for you.
May 05, 2007 | GE GSS25JEMWW Side by Side
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
113 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
