Question about XM Radio (XMP6000)
XM Radio Cutting In and Out
I have the Delphi XMCK-5KC XM radio. When I use it at work, the signal will cut in and out about every 2-3 seconds. This problem seems to happen when the output audio level is set high. The unit shows 2 bars for satellite signal and 3 bars terrestrial signal.
Does anyone have any suggestions to solve this problem or what is causing it.
Thanks in advance.
Posted by neill123 on
3 Related Answers
Anonymous
  • 83 Answers
SOURCE: XM Satellite Radio
you have checked all the connections? which make and model is it so i can be of further assistance...
Posted on Jun 14, 2007
Anonymous
SOURCE: My xm radio stopped working in a 2009 silverado.
Having the same problem in my 2009 Malibu. Have received 8 refresh signals and talked to the XM Techs 4 times. Taking car to dealership on Monday. Highly frustrated.
Posted on Apr 22, 2010
sharejoin
  • 20 Answers
SOURCE: Repair of XM Radio
I got my fixed at ebay, Item number: 360433194290
Posted on Feb 09, 2012
How do i refresh xm radio ?
Go to Channel 0 and get your serial number. Then, make sure you have a good signal, leave radio on Channel 1 for 1/2 hours after calling 1-800-XM-RADIO and ask they to refresh your radio. They will tell you how long to wait - okay?
Jun 17, 2010 | Delphi SKYFi XM Radio Receiver
ID 4Z9AB0MC activated 2 days ago. Cannot select channels. Thumbwheel only displays 3 channels, ch.0,1,247. When pre/dir is pressed and a channel is selected, the selected channel number flashes...
Use plug-in power supply and leave on channel 1. Call XM (1-800-XM-RADIO) and ask them to "refresh" your radio. WAIT 1/2 hour, then check your channels. Make sure you have a decent signal too (can hear Channel 1 okay) before you call XM for the 'refresh signal' for your new radio.
Dec 21, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
My Delphi Roady XT will not maintain signal
if you plug and unplug your antenna connection to the receiver a lot it loses the ground(shielded) line connection, if your lucky you can take a safety pin and CAREFULLY bend the radios 4 outer shell antenna contacts inward to make contact with the antenna connector, if its the plug on the antenna,try pushing wire in toward plug connection to the radio...delphi never had much for life on any external products that fit their XM radios but when you need repl parts boy are they waiting for you, and they got them
Aug 30, 2009 | Delphi Roady XT XM Radio Receiver
Delphi SKYFi3 XM Radio Repeater
You begin by setting up your existing (((XM))) antenna the one that came in your home kit (not included in repeater package) in a location that gets good reception of the (((XM))) signal. This may be outside, or on a south facing window sill. This antenna gets plugged into the rear of the Delphi (((XM))) Radio Signal Repeater Transmitter. A power jack is right next to the antenna connection, and should be plugged in and to the wall with the included power supply. There is also a "PWR OUT" selector switch on the rear of the unit which allows you to control the strength of the signal transmitted from the unit.
Once the power and antenna are attached, both blue indicator lights will light up on the face of the unit. The blue antenna indicator will light up only to signify that the antenna is attached correctly. It does not let you know whether your antenna is in a location receiving a good (((XM))) signal or not. You will have to look at the signal strength indicator on your (((XM))) radio receiver do determine best location for the (((XM))) antenna.
Once you have this setup, place the Repeater Antenna close to your existing (((XM))) Radio and plug it into your antenna jack on the (((XM))) radio cradle. This connector is identical to your (((XM))) Home Antenna provided with all Boom boxes and (((XM))) home receivers and kits so compatibility is guaranteed. The Repeater Receiver Antenna does not require any separate power connections. Hope this helps!
SATELLITE RADIO WAREHOUSE
Jul 10, 2009 | Delphi SKYFi3 XM Radio Receiver
Xm radio
Looks like my company is going to purchase a new fm radio for the company truck, I should be able to plug the xm radio into it.
Jun 03, 2009 | Delphi SKYFi XM Radio Receiver
XM Radio
My XM just recently started to cut out in certain locations that had no problem before. It seems to be getting a good signal the screen display does not cut out. I lose volume and get static just in certain spots. Anyone know where I should start looking for a fix.
Jun 26, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Delphi Roady XT Quit Working
Chances are it's not picking up the XM signal. First, contact XM to resend your setup. if that doesn't work check your antenna connections.
Oct 31, 2006 | Delphi Roady XT XM Radio Receiver
XM reciever FM transmitter problem
hi Mr.Frazier....is the xm radio hardwired installed? if it's a yes you have to go to a professional(bestbuy, retailers) to have the connection check.. the problem is not within the xm radio..it's on how it was installed or set up...
If the radio was not built..well, that's much better we just have to check the audio connection from you're xm to fm radio (make sure to check if what band it is connected..such as AUX,CD etc.) if there's a sound but you're only getting preview channels..refresh must be send on the radio...you can call xm to ask for that OR do it online at www.refresh.xmradio.com and type in your 8 digit radio I.D just have to follow the activation instruction faithfully...Godbless!
Aug 26, 2006 | Delphi Roady2 SA10085 XM Radio Receiver...
Car Audio & Video Logo
Top XM Radio Car Audio & Video Experts
xxxxxx xxx
 Mikey
Mikey
Are you a XM Radio Car Audio and Video Expert? Answer questions, earn points and help others
