Whirlpool ED5HHEXT Side by Side Refrigerator Logo
Posted on Feb 18, 2018
REGULARLY MAINTANANCE I HAVE MOD ED5HHGXTQOO S/N HRT4480068 I WOULD LIKE TO KNOW ABOUT THE WATER FILTER AND WHAT DO I NEED TO DO MAINTAIN THIS REFRIDGE ,,, [email protected] JERRY L HATCHER
How and where does one clean the filter on a defy autodry? I need to check as there is a warning light which i need to check as it does not want to get warm.
https://www.manualslib.com/manual/926961/Defy-Autodry.html?page=7#manual
Quoting:
Cleaning the Lint Filter
The lint filter, which is located behind
the door, should be cleaned after each
load to maintain optimum drying
efficiency.
The filter and filter cover are located
inside the door surround front.
Insert two fingers into the two large holes
and pull the filter cover free of the door.
Remove the filter mesh and clean off all
the lint by gently rubbing the filter mesh.
Replace the filter mesh and then the
cover.
Ensure that the filter is in position before
closing the door.
Cleaning the rear Air Intake Grille
The air intake grille, at the bottom rear of the machine, should be cleaned regularly to
maintain optimum drying performance.
Remove any obstructions and dust the grille off with a soft brush
Defy autodry Owner Manual Unsuitable Materials
Jul 02, 2018 • Dryers
My diswasher is not wash
There are many probable causes of failure .
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishwashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
Nov 03, 2010 • Dishwashers
Dishwasher will not clean very well
4helpful
Dishwasher not cleaning food is still on dishes
[email protected] It leaves calky residue on glasses. Is there a filter we need to clean in the water inlet?
Oct 01, 2010 • Dishwashers
Hello My Dishwasher, whne finished a cycle...the dishes are coming out with a white crusty film all over them and looking worse than they do before they go in and I don't know why this is happening?
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
I need to know which is the Serial or part number of the Water filter of the Kenmore Refrigerator Mod 106.58953800 I need to replace it and get a great price Where?
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Refrigerator-Parts/9030/0046/046/Model-10658953800/0582/0165000?keySuffixId=&productTypeId=&searchModelNumber=10658953800&blt=06&subCompDesc=CABINET%20PARTS
Film left on dishes
2answers
Maintanance
regularly change the engine oil every 1500 km or every 2\3 months whenever required, and also regularly check the tyre air presure \,that will help your bike to give a good mileage, regularly get a check up for your bike
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
