1995 Chevrolet Astro Logo
Posted on Apr 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Headlight swicht broke
Headlight swich broke
Greg Bernett
Level 3:
  • Chevrolet Master 2,993 Answers
  • Posted on Apr 27, 2010
Greg Bernett
Chevrolet Master
Level 3:
Answers
2993
Questions
Helped
2781920
Points
13428
Removal & Installation
  1. Disconnect the negative battery cable from the battery.
  2. Remove the lower steering column cover-to-instrument panel screws and the cover.
  3. Remove the instrument cluster trim plate-to-instrument cluster screws and the panel, then allow the panel to hang to the left side by the wiring.
  4. Disconnect the electrical connector from the rear of the headlight switch.
  5. Disengage and remove the headlight switch from the instrument cluster trim plate.
To install:
  1. Connect the electrical connector to the rear of the headlight switch.
  2. Engage and install the headlight switch in the instrument cluster trim plate.
  3. Install the instrument cluster trim plate-to-instrument cluster screws and the panel.
  4. Install the lower steering column cover-to-instrument panel screws and the cover.
  5. Connect the negative battery cable to the battery and check operation.
2answers
Low beame headlingh not workinc
Always change in pairs, for starters . high low swich faulty , or check headlights againe. to make shure, they are pluged in currectly. Oldsmobile is a good one for this problem. What kind of vehicle would help. start whith obvious if it worked before it should still work after changing headlights regardless. Possible headlight swich itself . Check headlight connections first. Go from their. Good luck.
Daytime running lights are not working. The regular headlights are though. The light symbol on the driver's side keeps blinking to let me know the daytime running lights are out. i swiched all the
There is a microprocessor in the instrument cluster that grounds the DRL relay - do you know if the relay has power from the headlight fuses and is being grounded by the processor ?
Cant swich gears caluom stick broke
not a real hard fix, but you should be able to get the whole column at a salvage yard for cheap
Overheating
batter drains down. Turn engine of, let it cool, check water and oil. You should replace oil and automatic transmission fluid
Headlights 1994 dodge ram 1500
alot of vehicles have a seperate fuse and/or relay for the high and low beams. if you can't find a problem there it could be the swich itself.
1987 mustang headlights
yeah the swich is shorted and i bet youll see its melting when you pull it out, let me know
1991 honda accord ex headlight problems
Hello, firstly I was wondering if the lights shut off when you pull the switch off the harness?
If YES, then THAT switch or wiring could be bad
if NO, then it's most likely the body control module
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
