I went on vacation and my brother house sat my apartment. He was able to get into the service menu and basically screwed up the geometry and convergence. The Widescreen works fine when I play a DVD, but the other settings (Full & Standard) are out of whack. I downloaded a service manual and entered the service portion of the TV to attempt to fix it, but I cannot get a good picture. For example, Theaterwide 1 and 3 are OK, but the other settings are so distorted it's not funny!
Please help!!
SOURCE: PROJECTION TV Phillips 9P6031c103
this is what convergance looks like;
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
if pix is dark their is 6 adjustments knobs in the front of the tv under the screen and behind the plastic cover. the top three are the brightness bottom three is focus.
SOURCE: Philips 32PW4523 with no widescreen options
no way to recover that info without obtaining a good service manual that has the default info loaded. Thats why you should always write evrything down that you change in the service menu and never change anything without having the service manual so you will know what the items sre what your adjusting. I can post a link where you can get a good service manual if you would like.
SOURCE: My convergence on my Toshiba 57'' is out of whack.
did you try to set the convergence adjustment on the remote control? there is a pattern (crosshatch) which you can adjust the convergence of RGB guns,If it cannot be done on earth as it is an heaven... you must open the back cover and look at the liquid coolant at blue gun, that liquid acts as a coolant at the same time as lens, check the level of liquid, usually it leaks and need a repair kit for replacement,make sure not to drop the coolant on the board that's conductor and corrosive.
SOURCE: fuzzy/ distorted tv pic
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by ejaparks on Mar 03, 2011
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Here is an example photo....
