Casio QT 6000 Point of Sale Terminal Logo
Posted on Apr 22, 2010
Show subtotal at finlist
I would like to know how can I see the subtotal while Im in the fin list, when I hit subtotal, it takes me back to the menu shift, how can i stop that?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 18, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
95
Points
HOW TO PRINT 2ND COPY OF BILL
Mohammad Azhar
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 5 Answers
  • Posted on Aug 20, 2010
Mohammad Azhar
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
5
Questions
0
Helped
3841
Points
7
Please try this:- go to PGM-3 select key features select function key- hit sub total see detail functioning of sub total. if you find any link delete it and hit esc.key till you reach in original mode .
We have a xe-a407 Sharp cash register and are having a problem with the tax on discounted item. Ex. If i have an item at $8.00 and $4.00 and subtotal and press 50 and button%1(DC) to take 50% off subtotal...
Many such problems can be resolved by returning to the instruction manual.
It is only by following the instructions exactly you will discover whether or not there is a machine fault or an operator fault...
Setting for condiment on pcr t2300 I have an error message that I can not get off I have tried everything pLease give me ahand
turn key to program and unplug and plug back in while holding receipt feed button. (all f's will show in display) then hit subtotal to return to normal. To clear the item requiring a condiment with key in program press 3, then subtotal , then 0, then the button causing the error then subtotal to exit...turn key back to reg1
1helpful
2answers
I have a casio te 4000f and it will not let anyone ring in when sub total pressed it is counting down in 1p also saying buffer full??? help
Ok. See if you can get rid of the buffer full error for a start. try pressing clear (C) then press Subtotal. You should see an amount on the display. Now press the ERR CORR/ CANCEL button. This should stop the sale that you are stuck in.
Turn the key to Program mode. If it gives error as you turn the key, then you haven't finshed in REG, turn back to REG and try to end the sale first.
If you see P01 on the display, it has worked and then do this:
1 SUBTOTAL 0 CASH SUBTOTAL 3 SUBTOTAL 0 CASH SUBTOTAL.
Now turn back to REG and try it.
If it still didn't work, let me know what happened, and I'll show you another method
If anyone needs a Casio TE-4000F manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-3000S_and_TE-4000F_and_TE-4500F_dealers_manual.html
When I put a sale of 1.00 and hit taxable it prints -1.06 when I hit subtotal, then i pt 2.00 and hit CA AMT Tend it puts 3.06 and the drawer opens. it should be .96 change???
Subtotal is only hit after all sales...Labor or merchandise have been entered, then you hit the tax button, subtotal and then enter the amopunt of money handed to you and the CA/ Amt Tendered button...all tax will be added and tell yo the change to give back!
I hope I answered yur question
I lost the manual and don't know what step to take after i plug in the usb to see what i backed up in the past and to back up current stuff.
In the start menu, go to my computer or with vista, computer it should show your harddrive listed. Right click on that drive and hit open. You should see all the files on that harddrive. click on the file you want to open and you will see the contents.
8helpful
2answers
INSTRUCTIONS FOR THE KEYS ON THE CALCULATOR
To get a subtotal when adding, finish entering the last number before the subtotal, hit the +, then hit the diamond/pound sign key (just above the 7)
To get a grand total when adding, finish entering the last number in your list, hit the +, then hit the *.
6helpful
E026 error message Casio TK-7000
find out what plu it is then re pgm it
turn the key to PGM
enter 3 & press Subtotal
enter 0166 & press Subtotal
enter 0 and press the faulty PLU
now press Subtotal
enter 1066 & press Subtotal
now press Subtotal
turn the key back to Reg
BLACKJACK2 CAMARA IS MESSED UP
You probably have hit the effect button and selected negative, to get it back hit camera then menu on the right side, if menu doesn't show up hit the right side anyway and it will appear. Above it should say negative use the arrows at the top to change it back to normal.
Hi im trying to do a sim unlock on my sidekick
turn the phone on and hold the menu button and the one under it till the emergency menu comes....... Wen it comes up hold the menu alt and q then a pop up will show up sayin your settings are going to be reset hit ok and there u go
Top Casio Retail Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
