Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Help connect to internet
I no longer can use y laptop and connect to the internet like i used to
  • 2,277 Answers
Is there any other computer on line.
If laptop is the only computer then connect the laptop to the router with the cable and check if that works.
If you have other computer on line then you will need to check if your laptop is connected to the wireless network.
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Posted on Apr 22, 2010
Dell inspiron 1525 says limited or no connectivity
Could be an issue with the router. Try resetting the router.
Mar 08, 2017 | Dell Inspiron 1525 Laptop
I have a XP laptop that used to connect to my Uverse internet
Sometimes tech support advise to use manual ip address.
check out the work laptop settings. Is it manually configurated ip address?
if so... use the same settings on yours, EXCEPT the ip address itself, use the same gateway, same dns, etc... in the IP address, change only the last octect (last numbers).
Sep 14, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
I cannot connect to the internet with my laptop Toshiba?
You need to get the IP address, domain and other info from you internet service provider to set up the connection again.
Aug 21, 2009 | Toshiba Equium 100 PC Desktop
Acer aspire 5515 how to connect to internet
check if you have got an internet connection:
try windows update, if windows can access its automatic updates on the microsoft-homeserver,
then it is a browser issue
if so, come again stating: Operaion System used, how connect to internet(dsl, wifi, modem etc.)
and the browser (firefox, internet xplorer, which version, etc)
if not, do same. see you
Jun 18, 2009 | Acer Aspire 3000 Notebook
My samsung np-r60 model notebook wont connect to the internet.
Easiest thing to try first is updating your wireless drivers.
go to Samsung's support page and find the latest version, download and install.
Let me know if you need any more help.
Jun 13, 2009 | Computers & Internet
Looking 4 button to enable internet and find w/l network
are you trying to use or get internet by wireless connection, make sure that your radio button is enabled, in order for you to get the internet connection signal.
Jun 02, 2009 | HP Pavilion dv7-1132nr Notebook PC
I can't connect through the VPN and Internet at the same time
when you have 2 connections open at the same time you need to tell the computer which one you want to use to connect to the internet. the way to do this depends on the operating system but in windows the setting is in advanced properties of the network connection in control panel
Jan 21, 2009 | Belkin Wireless Cable/DSL Gateway Router
Wireless internet
Try this:
if your using wi-fi:
-right click network
-click diangnose and repair (windows will automatilly diagnose problem regarding on your connection)
hope this could help :)
if your using DSL connection:
-diagnose and repair (windows will automatilly diagnose problem regarding on your connection)
-if nothing happens, turn off your modem, unplug n cable, then wait for 10 seconds, turn on modem, plug the cable
hope this could help solve your problem :)
Aug 27, 2008 | Computers & Internet
No connection to internet (wireless) on laptop
the telephone connection is lacking of your site!! but you can use the MODEM ROUTER, in order for you to able to function the internet..
Aug 25, 2008 | SMC Barricade g SMC2804WBR Wireless Router
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
83 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
