Question about Belkin (F5D7230-4) Router (587009)
I have a belkin 802.11g router but have lost the manual, I need the gateway starting http; to enter in to the internet so I can access it
  • 4,281 Answers
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.15.1
or
http://192.168.2.1
Or
http://192.168.0.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
If you are still not able to see use name and password screen then RESET it Press RESET button for 10 seconds it is in back side of router Then try with above ip.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Apr 22, 2010
  • 2,277 Answers
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
6ya staff
SOURCE:
I forgot my password, where do I go for assistance so they can email me my password
Resetting the System Password
If you forget your password and still cannot remember it after seeing your hint, click the I still can't remember the password link.
The Reset System Password page opens.
To obtain access to your system:
1. In the System Key field enter the 10-digit system key located on the bottom of your gateway.
2. In the Enter New Password field, enter a new system password. In the Confirm New Password field, reenter the system password.
3. In the Enter Your Hint field, enter an appropriate hint as described under "Setting a System Password" .
4. Click Submit.
Setting a system password protects your gateway settings from being modified or changed by someone who has not been given permission to do so. After setting a system password, you will be required to enter it whenever you attempt to access a gateway configuration page - for example, if you try to change the gateway's broadband connection settings or upgrade the gateway software. If a password has not been set,
a reminder notice is displayed when you attempt to access pages where settings can be changed.
To set your system password:
• Open a Web browser and access the gateway user interface by entering
http://gateway.2wire.net.
• Click the System tab.
• Click the System Password link in the System area of the Network at a Glance panel to open the Edit
System Password page.
1. In the Settings panel, click the Enable checkbox.
2. In the Enter New Password field, enter your password.
3. In the Confirm New Password field, re-enter your password.
4. Optional: In the Enter Your Hint field, enter a hint.
A hint is a word, phrase, or question that reminds you what the password is. There is an I forgot the password link on the password entry page. When you click this link, it shows you your hint and allows you to enter your password.
5. Click SAVE.
Aug 05, 2013 | 2wire (2701HG-B) Wireless Router
Belkin N1 Wireless ADSL2 Model # F5D8631-4 Router router default address (192.168.2.1) is not opening, even i have reset the router
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Dec 09, 2012 | Belkin Computers & Internet
How to find lost password for access
It is not likely you will be able to recover the password if the individual who implemented it is unavailable to provide it. Your only alternative is to factory reset the device according to the manual and then put in the necessary settings required. The default username and password for this device is easily found in the users manual for the device, found here:
http://www.belkin.com/support/article/?lid=en&pid=f5d8236-4&aid=14394&scid=942
Aug 13, 2011 | Belkin F5D8236-4 Router
I CANT ACCES TO THE BELKIN PAGE , I NEED SECURITY IN MY ROUTER
First you need to know the access ADMIN Username and Password for your router?
If you have the access then you can configure your router manually.
Identify what IP address of your gateway.
>Start>CMD>IPCONFIG
(check what IP address you have in gateway. use that ip address to access your router)
example.
>launch internet explorer then type the IP address into the address bar.
>http://192.168.1.1
you will be redirected to a page will it asked for username and password.
then you need to enter the information.
if you dont know the admin un and pw contact your ISP.
but most of the default UN and PW is
Username: admin
Password: admin
once you able to get into the GUI of your router then go to configuration for the PW to lock your network.
Jun 03, 2011 | Belkin Basic Wireless Router
I have lost my install disk for my Belkin wireless router #F5D5230-4. I have reformated my computer and need to reinstall my router what can I do?
Belkin has a great support site and this link here will take you a page where you can download a new manual, firmware updates, and even troubleshooting help with setting up the router with Comcast, Bell South, and Cox cable systems.
Good luck to you.
Feb 12, 2011 | Belkin (F5D7230-4) Router (587009)
I am connected but I have no internet access. I
Sounds like it could be a Gateway or DNS issue, is there anywhere you can enter the gateway and DNS addresses in the Belkin Other thing to check is the ADSL modem and the Belkin are not on the same subnet ie. the ADSL modem should not be 192.168.2.X. This is because the Belkin is a router and won't route to addresses in the same subnet
Mar 05, 2010 | Belkin (F5D7231-4) Wireless Router
Lost paraphrase Cod . Where can I get it
You need to access your router configuration page. Connect your computer to the router with an ethernet cable, check the default gateway and enter the default gateway in your browser address field, that will take you to the router configuration page.
http://technicalsupport.blog.friendster.com
Sep 18, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Cannot connect to internet
call ur isp ...ask for
1. ip address
2.subnet mask
3.default gateway
4.dns
or
1.ppoe - username and password
connect ur belkin to the computer
1. start - run - cmd - enter
u get a command prompt screen
2. type ipconfig
u will get the default gateway
close that black screen
3.open the internet explorer
4. type the default gate way in the address bar
5. it will ask for the user name and psw for belkin
6. check ur manual for default user id and the psw
7. u can see the main page of belkin
8. enter the first set of settings or the second set
save
==============i hope this will help u
Jun 04, 2009 | Belkin (F5D72304F5D7000) Router
I have (stupidly) disabled the NAT feature of my Belkin wireless G router, without specifying an IP address to access it, and so can get no access to the wireless network from any pc. Is there a way to...
to turn the NAT feature back on in the belkin router, just reset it.
And you can always tell what address (known as the gateway address) access the router, which ip,
by clicking start, run, and then type cmd and click 'OK'
in the black window that pops up, type 'ipconfig' without the commas and hit enter on your keyboard
look for the default gateway
if nat was on, or after you reset it,
its 192.168.2.1
type 192.168.2.1 in the address bar of internet explorer to access the router
most routers default password is ither admin , or password
spin
Jul 13, 2008 | Belkin Computers & Internet
Belkin (F5D7230-4) Router (587009) Logo
108 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Jeffrey Groves
Jeffrey Groves
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
