Question about Hitachi 52LDX99B 52" Rear Projection Television
52 Hitachi rear projection T.V. (model #, 53FDX01B)
52" Hitachi rear projection T.V. (model #, 53FDX01B) No picture, no sound red power light comes on, that is it, ckd all the e991,993, 994 fuses, all good. desoldered convergance chips still nothing?? any help?
Posted by rsweinsberge on
atelier mj
  • 70 Answers
Look for EP98, Q655 and D756.
Posted on Apr 22, 2010
The red power light comes on but nothing else works on my hitachi 53FDX01B PROJECTION TV
silly question but have you tried turning it on with the remote. if a tv has been turned off by remote and then power goes, turning it on by the tv switch will put the tv back in stand-by mode and you need to use remote.
just a suggestion.
Dec 13, 2013 | Hitachi 53FDX01B 53" Rear Projection...
Bright blue concave archs accross top of the screen with some yellowish ghosts on any lettering accross bottom of screen. This is a hitachi model 53fdx01b rear projection tv that normally has an excellant...
Sounds like a convergence failure, here is a tutorial I made:
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Sep 09, 2010 | Hitachi 53FDX01B 53" Rear Projection...
HITACHI WAS HIT BY LIGHTING.LIGHTING CAME THROUGH
i have a 52" that has the same problem just wondering if u have found a solution yet ????????/
Mar 02, 2009 | Hitachi 51F510 51" Rear Projection...
Hitachi 53" rear projection is losing its picture.
If you are not experiencing any shift in colors, it sounds like the power supply is failing since this will affect all three colors.
Feb 28, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Hitachi rear projecton tv
your model uses two STK392-110 Convergence ICs. Hitachi also recomends replacing the feed resistors which are two 2.2 ohm 1watt, two 1.5 ohm 1watt, one 3.3 ohm 1watt and one 1.8 ohm 1watt resistor. You can get repolacement ICs and resistors at the following link and they provide step by step installation instructions with pictures. Heres the link.
http://servicemanuals.vstore.ca/
Sep 30, 2008 | Hitachi 53FDX01B 53" Rear Projection...
TV repair
Good Day;
Try resetting the TV by unplugging it from the wall. Plug back in after 5 minutes. If, no fix; call for An Authorized Service Center and have come out and give you an written estimate B4 repairs, most repairs on PJTV's avg $525.00. Good Luck, big IRISH.
Aug 25, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Sound, but no picture
Had the same thing today. Iwas playing with the auto demonstration of on screen displays. Press and hold the power button (5 seconds) on the TV. The auto display will play. Press the power button again (TV will go off). Turn power on again. you should now have the picture back
Nov 14, 2007 | Hitachi 53FDX01B 53" Rear Projection...
53FDX20D
No...just that it was the regulator circuit - and I don't know if you can buy those anywhere...
Oct 29, 2007 | Hitachi 53FDX01B 53" Rear Projection...
53FDX01B Picture went black
is the screen lit up?
If so the video module is bad.
replace the surface mount caps app. 8 to 10
or replace module
guy9
Aug 20, 2007 | Hitachi 53FDX01B 53" Rear Projection...
Hitachi 52LDX99B 52" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Paul Bade
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
