Question about Craftsman 10" Table Saw
New table saw, timber runninig off away from guide, saw blade running its own line,do i need to reset the guide.
Posted by shirley728 on
Bobby Cavasos
    New Friend:
  • 3 Answers
I have the same problem but it is not the fence is the motor. This is a direct drive saw and the motor needs to be true to the fence. Sears has it set up to make some small adjustment but it is not enough to to true up the blade. I am in search of a good solution to at least make it cut straight when using the fence.
Posted on Jun 08, 2010
Awesome12
    New Friend:
  • 131 Answers
The guide is called a fence. The fence should be positioned to the right of the blade. When using the fence, the largest part of the board goes between the blade and fence. Fences are typically have some relief toward the end, so you don't get the blade cutting on it's way down, and then cutting again on it's way up.
Posted on Apr 22, 2010
1helpful
1helpful
Ryobi band saw blade does not cut straight
The side guides should be just off touching the blade (top and bottom) The thrust bearing behind the blade should be just off th blade while it is free running (T & B). The amount of blade exposed to the timber needs to kept to a minimum - like top guide abou 1/4" above timber. Then, correct tension for blade size :)
I'm a wife with a do-it-yourself knack. I recently purchased a Ryobi 10 in. BTS211 table saw. I find the manual complicated as far as how to actually use the device. Can you recommend where I can get...
I am a retired contractor.
I have a shop with a 10" table saw.
And I have opinions about safe operation.
For safety, turn saw off when making adjustments.
1) Raise blade:
There is a handle you turn to raise the blade.
If you are cutting 1/2" plywood, then set your blade at 3/4" or a bit more.
Keep blade low and away from hands.
Keep hands high and away from blade.
For 1-1/2" thick 2x4, I usually set the saw at 1" and run the board through, and then flip the board over and run it through again, taking 2 passes to make really thick cuts.
2) Blade angle
There is a second handle you turn to set blade at an angle up to 45 degrees
Angle cannot be set if saw blade is fully raised >> lower blade to half way or less and experiment.
Angle cuts are difficult if wood is not perfectly flat and square, or too long or too short (boy is that helpful ... but cutting angles takes some experimentation)
3) Table Guide
You stand behind power saw to operate
The saw table guide is on left side of blade and clamps across the table
The guide markings show inches >>> these are usually approximate
To set guide for accuracy, measure distance from blade to saw guide, and then clamp guide down.
4) Push sticks push sticks push sticks and other safety stuff
Let me emphasize safety first last and always
A table saw will chop your fingers off in a blink
On the plus side, I hear it doesn't hurt. But OMG.
There is a very strong human instinct to reach in with your hand when working on stuff
Train your mind >> if the saw is running, do not lean or reach into the saw
If a board is stuck >>> turn off the saw and wait for full stop
If you wear baggy clothes of a loose shirt, the saw will grab you and pull you in too fast for you to react
Keep your clothes tight and your arms bare
Always use push sticks or push boards::
Notice the saw blade is set low
Two push sticks are used to assist when cutting short board > one stick holds down the board ahead of blade, the other stick is pushing board through saw.
Keep your hands away from the blade no matter what.
The person stands behind and to the side of the board being cut.
The cut wood is supported by a catch table (in this case there are rollers)
Where to stand
Obviously you stand behind the saw to cut wood, and sometimes with long pieces, you can move in front and pull them through, and sometimes with large plywood you stand kinda back and to the side.
Why not stand directly behind a saw? Because saws throw stuff back.
When 'ripping' a board lengthwise as shown in photo above, if the saw catches the board just right, it will throw it backwards like a spear.
If a board 'binds' the saw causing saw blade to stop, then turn off saw, back up the board, and cut again.
Crosscut guide
The saw comes with a T-shaped guide that fits into a groove.
This is a 'push stick' >>> you use it to cross cut a board, and it lets you stand to the side of the saw blade so things wont flip back on you
When using the cross cut guide, remove the table guide that clamps across the saw, or push the table guide WAY back so pieces don't get caught in a bind and the blade flips up the piece and hits you in the face
Remember, the saw throws everything backwards
The saw is strong and fast, and you are best when traveling slow and without rush around your strong friend.
Oct 15, 2010 • Garden
My bosch 4000 will not run at full speed. Not using ext cord and electricity in my home is working.
This is common "affiction" for all table saw... and easy to fix, it applies to all power/hobby table saw in existence regardless of brand, manufacturer or model, if electrical problem is excluded, something is holding the blade:
1. switch off power
2. remove power cord from the socket
3. lift panel in the centre of the table (you did not supply exact model
4. remove nut holding the blade and the blade, pay attention to the direction of the teeth
5. clean bottom of the blade groove from all debris and especially long pieces, slivers, of offcut timber
6. put blade back in place and tighten the nut, check if it is moving freely, check if it is not slipping or wobbly
7. put table panel back, find these two pesky little philips screws which run somewhere on the floor and mount them back as well...
8. connect power and switch on and instantly off, check the blade again for slippage/wobbliness
9. mount back protection gards, try test cut
10. if test cut was successfull, use normally till next sliver fell in...
If test cut was unsucessfull - if this is open motor, check for debris inside ot the motor or even fan, then check brushes on the rotor if they are not carbonised too much or even burnt.
Do remember that this is not a toy, always disconnect physically at power point if you do any maintenance, blade will cut through timber, ocassional nail and through your fingers...
Do always wear googles or face shield, saw produce chipping and splinters while it works, you have two eyes but no spares.
Hope this advice will solve your problem, please do not hesitate to leave note how did you went :-)
Aug 17, 2010 • Bosch Saws
2answers
My combination saw D27105 is making a bad noice when attempting to start and is not running up to normal speed. can anybody help here ?
it is bit of timber on the bottom of the saw assembly...
1. switch off the saw
2. remove power plug
3. remove screw and clear protector assembly
4. remove centre panel (as to changing the blade)
5. remove blade and clean dust furrow below it from all debris
6. re-assemble in reverse order
7. mount safety protector assembly
7, connect power cord
8. start in shor burst and switch immediatelly off, after blade stop spinning, check blade assembly if not wobbly.
this should solve your problem.
if you find this advice useful, please do not hesitate to leave comment and give me your vote4 fo rme, thanx!
Delta saw model no. 28-245 saws a taper form top of wood to bottom why does it not saw a stander line Delta saw model no. 28-245 s/n 91B1335
Sounds like your table is tilted. Put a small square on the table against the blade, then adj the table to it. If that is not it, then the blade guides are off up and down, back off all the guides, wheels, turn the blade by hand, get it tracking in the center of the tire, then bring the bearings up the blade, don't push it , just touch it, then bring in the guides, again, make sure it doesn't push it, the guides stop it from going off, it should track by itself. Hope this helps.
Feb 05, 2010 • Delta Saws
After moving the table saw to a new residence i cant get the rip fence to line up with blade.i tried everything that was in the trouble shooting guide.
I am guessing it must be damaged beyond the adjustments. Are you sure the blade is aligned with the table? If not that could be the problem. I have most rip fences for craftsman belt drive saws available, Ebay 'Hokienpokie" or contact me via email, if you need another fence. Jim
After inserting a blade in the quick lok, the blade does not line up straight with the guide. The blade goes beyond center.
The blade lines upaccording to the rotor shaft and has nothing with the guide except for the fact that the table has been droped and bent out of place or has been tweeked out of place somehow, usually hitting the floor from the table top causes this. Loosen the table screw to see if you can get it back in place and square it back up, hope this helps, good luck!
1helpful
Blade and shaft moves left and right
You may want to try a new blade. ANY TEETH MISSING CURRENT BLADE??
Please rate. Thanks jj505
Mar 28, 2009 • Saws
Craftsman 10" Table Saw Logo
Top Craftsman Saws Experts
Mike
john h
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
