Question about Acer Televison & Video
32inch Acer LCD TV, screen goes funny, need to unplug
I have a 32inch Acer LCD TV, AT301W. When I first turn, it works for a minute and then the screen either goes black, or green, or checkers, sometimes it freezes on a picture. No matter what I can't turn it off from remote or TV, I have to unplug wait 30 seconds and plug back in. Sometimes I need to do this up to 3 times before it starts to work fine.
Posted by josterr on
5 Related Answers
Anonymous
  • 208 Answers
SOURCE: Sharp aquos lcd screen goes blank
The problem is most likely the the screws are loose on the inverter boards. The screws must be tighted as they provide the ground to the inverter bds. The inverter boards are undet the shields on both sides of the unit after pulling the back cover. One way to make sure that you are losing back lights and not video is when your picture goes black, shine a flash light on the screen at an angle and will see the video is still there. This mean the back lights are out. If you do not see the video it may be another problem
Posted on Feb 05, 2008
Anonymous
SOURCE: LCD TV picture is green
I unplugged my TV for 15 minutes and that fixed mine a few months ago, the problem returned today, I noticed that it was only happening on the HDMI 1 port, when using my Xbox (on HDMI 2) the problem didn't happen
if you only have 1 HDMI source, try switching to the other port
Posted on Feb 13, 2008
Anonymous
SOURCE: Viewsonic N3000w LCD TV randomly shuts off...
Actually its a panel fault. You will need new inverter board for the panel. (That is if you get the power and sound, but no picture)
Posted on Sep 12, 2008
Anonymous
  • 53 Answers
SOURCE: Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Posted on Apr 30, 2009
OT Bobby
  • 105 Answers
SOURCE: JVC LT 42x688 no picture just sound
Sorry, this has no easy fix. The good news is you do not need an LCD Panel. The bad news is the Video Processor has a problem.
This TV has x3 Boards. The one you should replace first is the one in the middle. If this doesn't fix it, try the one on the right. The Part #s are on the Boards if you wanna try ebay.
Posted on May 06, 2009
I have lines,multy coloured running down r/h side of sreen.about 5mm wide.after a while the tv gets funny screen e.g black and funny colour fading in and out. awa mod mhdv3209-f4 32inch
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
Feb 16, 2015 | Televison & Video
Issue with Samsung LE32B450. After the TV has been on for about 5 minutes, when you change channel the screen goes blank and the sound goes off. However, the TV is still on as pressing the power but
Just do a hard reset to this set and check. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This must make it a hard reset.
Jan 12, 2013 | Samsung LE32B450 32 in. LCD TV
My Sansui 32 Inch LCD screen shuts off, after a minute. The power remains on - the screen just switches off.
This may not work but i had a similar problem. My 32inch sansui LCD TV would switch off after about 10-20 minutes. I had to unplug it to get it going again. So i decided to open it as the warranty was long gone anyway. Very easy to open the back. I checked to see if anything was "swollen" as some sights suggested, but found nothing burnt , blown or swollen. Then i thought about heat? So i left in on without putting the metal backing plate back. It worked! when i put the plate back.....20 minutes and it shut down. So i just left the metal backing plate off! And no its not dangerous as the sansui has a protective plastic backing, that covers the metal one, that is better ventilated and protects the bits and pieces. Its been a week now and its fine.
Feb 15, 2012 | Sansui 32" TV
My 32inch LCD tv screen goes black and no video shows while the sound evrythingf else works. what could be wrong? am i looking at a large cost to repair? cheers Aa
Now,tv turn on u have a picture few sec.than dies have sound left only?Yes,than those 2 tv long boards call the LCD inverter boards are dead.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 refurbishes long LCD inverter boards for the replacement.
Jan 30, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
What would cause the sound on a lcd hdtv 32 inch flat screen tv to just stop?
What other device are you connecting to your tv and how are you connecting it?
If you connect via a single HDMI cable that may be causing your audio problem. Some Tv and STB have handshacking issues which can knock out audio and/or video. The only solution would be to replace the HDMI cable or switch to composite cables.
Dec 14, 2009 | Element Electronics FLX3220F 32 in. LCD TV
I cracked my new 32inch lcd tv screen need new one
Don't know what brand it is but, it really doesn't matter the screen or lcd panel cost as much or more than a new set. Sorry.
Aug 24, 2009 | Televison & Video
Dec 22, 2008 | JVC LT-40X776 40 in. LCD HDTV
After power outage, TV screen is blank
It sounds funny but, unplug the set for 30 seconds to allow the TV to reset then see if the problem still is there.
Apr 10, 2007 | JVC LT-26WP84 26 in. LCD Television
Televison & Video Logo
80 people viewed this question
Top Acer Televison & Video Experts
Marvin
Marvin
Paul Bade
Harrie
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
