Hummingbird Exceed 10.0 Logo
Posted on Apr 22, 2010
Exceed 10.0, after i use the scroll bar to see more windown, the command console will auto. show "0" and i cannot type any char. in this command console. Thanks
How to switch on poe function at switch port
Hi
Instructions
telnet to the IP address of the Cisco switch
Enter the telnet access password for the Cisco swict when requested, and then the "Enter" key.
Type "enable" at the command prompt, and then the "Enter" key.
Enter the Privileged Exec password when requested at the command prompt, and then the "Enter" key. Then enter "configuration terminal" at the command prompt, and then the "Enter" key.
Type "interface fastethernet0/1," replacing the "fastethernet0/1" with the name of an interface in which you wish to enable PoE, and then the "Enter" key. Then, while in interface configuration mode, type "power inline auto" and then the "Enter" key. Repeat this step for each interface in which PoE is required.
Type "end" at the command prompt and then the "Enter" key, copy running-config
Below is some commands to run, I don't have any power on the interface but this will show you if this is working...
SW1#sh power inline fastEthernet 0/1
Available:360(w) Used:0(w) Remaining:360(w)
Interface Admin Oper Power Device Class Max
(Watts)
Fa0/1 auto off 0.0 n/a n/a 15.4
Run this command to see the interface is up.....
SW1# sh interface fastEthernet 0/1 ' in protocol
FastEthernet0/1 is up, line protocol is up (connected)
SW1#sh cdp interface fastEthernet 0/1
Encapsulation ARPA
Sending CDP packets every 60 seconds
Holdtime is 180 seconds
Thanks
tip
How to set the Clock Rate in the serial interface on a Cisco Router
From the UserEXE mode type enable command to get the Privilege mode
Router1> enable
Router1#
from here type configure terminal to get into the Global configuration mode
Router1# configure terminal
Router1(config)#
from the global configuration mode go to the serial interface where you want to set the clock-rate type the command interface serial <serial interface number>
Router1(config)# interface serial 0/0/0
Router1(config-if)#
from here type clock rate <rate> command
Router1(config-if)# clock rate 64000
But clock rates are only set if the serial interface is DCE. To check that the interface is DCE type show controllers serial <serial interface number> in the Privilege mode that is Router#
Router1# show controllers serial 0/0/0
Enjoy networking.
on Jul 03, 2010 • Computers & Internet
3helpful
2helpful
2answers
Webpage error details
100% working IDM fake key block problem
http://atips4pc.blogspot.com/2012/02/how-to-solve-idm-fake-key-serial-number.html
My 2 year old stepped on{or dropped } my Dell xps m140 and cracked the screen. I thought I would replace it myself..Before I do, I hooked up an external monitor to see if it still operates properly, well...
This error is also cause by the hard drive storage of your pc notebook, if you know how to locate the hard drive you just have to remove it for a while and then put it back, some loose connection of the hard drive cause the problem, if you find it still not working, you need to repair the system startup of Windown XP it is corrupted that's why it wont start.
Before attempting to check the physical parts of your notebook, try first to check and recover the Windows startup system.
In windows startup repair you can use the Windows Recovery Console.
Source: http://support.microsoft.com/kb/314058
Here's the step to start in Recovery Console:
  1. Insert the Windows XP CD into your CD drive and restart your computer. If you are prompted, select any options required to start (boot) from the CD.
  2. When the text-based part of Setup begins, follow the prompts. Select the repair or recover option by pressing R.
  3. If you have a dual-boot or multiboot system, select the installation that you want to access from the Recovery Console.
  4. When you are prompted, type the Administrator password.
  5. At the command prompt, type Recovery Console commands, and then you can refer to the commands that are listed in the "Available commands within Windows Recovery Console" section.
  6. At any time, you can type Help for a list of available commands.
  7. At any time, you can type Help commandname for help on a specific command. For example, you can type help attrib to display the help on the attributes command.
  8. At any time, you can exit Windows Recovery Console by typing Exit at the command line.
After you start the Windows Recovery Console, you receive the following message:
Microsoft Windows(R) Recovery Console
The Recovery Console provides system repair and recovery functionality.
1: C:\WINDOWS
Which Windows Installation would you like to log on to ?
(To cancel, press ENTER)
Enter the number for the appropriate Windows installation. In this example, you would press 1. Then, Windows prompts you to enter the Administrator account password.
Note If you use an incorrect password three times, the Windows Recovery Console closes. Also, if the Security Accounts Manager (SAM) database is missing or damaged, you cannot use the Windows Recovery Console because you cannot be authenticated correctly. After you enter your password and the Windows Recovery Console starts, type Exit to restart the computer.
Use the fixboot command to repair the startup boot of your notebook.
2 pass assembler in c
pass1:
#include<stdio.h> #include<string.h> void main() { int lc; int s,num,f=0,f1,l,i,n=0; FILE *fp1,*fp2,*fp3; char lab[10],op[10],val[10]; char a[15][15]={{'S','T','A'},{'S','T','L'},{'L','D','A'},{'L','D','B'},{'J'},{'J','E','Q'},{'J','S','U','B'},{'C','O','M','P'},{'S','T','C','H'},{'R','E','S','W'},{'R','E','S','B'},{'W','O','R','D'},{'B','Y','T','E'}}; char b[20][10]; fp1=fopen("INPUT.DAT","r"); fp2=fopen("SYMTAB.DAT","w"); fp3=fopen("INTER.DAT","w"); fscanf(fp1,"%s\t%s",lab,op); if(strcmp(op,"START")==0) { fscanf(fp1,"%x",&lc); fprintf(fp3,"%x\t%s\t%s\t%x\n",lc,lab,op,lc); } s=lc; while(!feof(fp1)) { fscanf(fp1,"%s\t%s\t%s",lab,op,val); if(strcmp(op,"END")!=0) { for(i=0;i<13;i++) { if(strcmp(op,a[i])==0) { f1=0; break; } f1=1; } if(strcmp(lab,"$")!=0) { for(i=0;i<n;i++) { if(strcmp(lab,b[i])==0) { f=1; break; } f=0; } if(f==0) { fprintf(fp2,"%s\t%x\n",lab,lc); strcpy(b[n++],lab); } } fprintf(fp3,"%x\t%s\t%s\t%s\n",lc,lab,op,val); if(f==1) fprintf(fp3,"ERROR:SYMBOL ALREADY DEFINED\n"); if(f1==1) fprintf(fp3,"ERROR:WRONG OPCODE\n"); num=atoi(val); if(strcmp(op,"RESW")==0) lc=lc+(num*3); else if(strcmp(op,"RESB")==0) lc=lc+num; else if(strcmp(op,"BYTE")==0) { num=strlen(val)-3; lc=lc+num; } else if(strcmp(op,"WORD")==0) lc=lc+3; else lc=lc+3; } } fprintf(fp3,"%x\t%s\t%s\t%s\n",lc,lab,op,val); l=lc-s; fprintf(fp3,"PROGRAMLENGTH %x",l); fcloseall(); }
pass2:
#include<stdio.h> #include<string.h> #define q 11//N0. of elements in array A void main() { int lc,ad,address,t=0; int s,num,l,i=0,j,n,len,ni=0; FILE *fp1,*fp2,*fp3; char lab[10],op[10],val[10],code[10]; char a[15][15]={"STA","STL","LDA","LDB","J","JEQ","JSUB","COMP","STCH","ADD","SUB"}; char b[20][15]={"14","32","03","69","34","30","48","28","24","16","0C"}; char sym[15][10]; int symadd[15]; fp1=fopen("INTER.DAT","r"); fp2=fopen("SYMTAB1.DAT","r"); fp3=fopen("OUTPUT.DAT","w"); fscanf(fp1,"%x\t%s\t%s\t%s",&ad,lab,op,val); while(strcmp(op,"END")!=0) { fscanf(fp1,"%x\t%s\t%s\t%s",&ad,lab,op,val); t++; } t--; fscanf(fp1,"%s%x",val,&len); fclose(fp1); fp1=fopen("INTER.DAT","r"); fscanf(fp1,"%x\t%s\t%s",&ad,lab,op); if(strcmp(op,"START")==0) { fscanf(fp1,"%x",&lc); fprintf(fp3,"H^%s^00%x^%x\n",lab,lc,len); fprintf(fp3,"T^00%x^",lc); if(t>10) { fprintf(fp3,"1E"); t=t-10; } else fprintf(fp3,"%x",t*3); } s=lc; while(!feof(fp2)) { fscanf(fp2,"%s\t%x",sym[i],&symadd[i]); i++; } n=i; while(!feof(fp1)) { fscanf(fp1,"%x\t%s\t%s\t%s",&ad,lab,op,val); if(strcmp(op,"END")!=0) { if(strcmp(op,"RESW")!=0&&strcmp(op,"RESB")!=0&&strcmp(op,"WORD")!=0) { if(strcmp(op,"BYTE")==0) { for(i=2,j=0;i<strlen(val)-1;i++) { code[j]=val[i]; j++; } code[j]='\0'; fprintf(fp3,"^%s",code); ni++; } else { for(i=0;i<q;i++) { if(strcmp(op,a[i])==0) { strcpy(code,b[i]); break; } } for(i=0;i<n;i++) { if(strcmp(val,sym[i])==0) { address=symadd[i]; break; } } if(ni<10) { fprintf(fp3,"^%s%x",code,address); ni++; } else { fprintf(fp3,"T^00%x^",lc); if(t>10) { fprintf(fp3,"1E"); t=t-10; } else fprintf(fp3,"%x",t*3); ni=0; } }
} } else break; } fprintf(fp3,"\nE^00%x",s); fcloseall(); }
instrutui 1.Copy all the contents into turboc3 2.Execute the "PASS1.C" program 3.Execute "PASS2.C" program Note:The output of "PASS1.C" is used as the input to "PASS2.C"
1helpful
HELP! Laptop will not boot up!
Try an XP repair:
Boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Top Hummingbird Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Hummingbird Computer and Internet Expert? Answer questions, earn points and help others
