Hi,before replacing the screen,why don't you dry out the LCD screen to get rid of the moisture,you can use a hand dryer to dry out the moisture of the screen after taking it out.If after drying the screen the problem remains,then you can go ahead to get a new screen.
Here is a detailed step on how to dissassemble your P1i;
STEP 1
Tools required: Torx 6 screwdriver, Phillips size 0 screwdriver
STEP 2
Run your fingernail around the join of the back cover and then pry the back cover off
STEP 3
Now remove the two screws you can see at the top of the phone
STEP 4
STEP 5
Remove the keypad and lift the part underneath from right to left, this will reveal two more screws. Remove these screws
STEP 6
Remove the metal plate that the screws were holding in place and you now have access to the ribbon which attaches the screen to the circuit board
STEP 7
STEP 8
You have now removed the LCD screen
then you dry,
Reverse the whole process to reassemble.
However,the LCD screen costs $92.if you have the reason to purchase it.
Thanks and take care
