Question about Black & Decker 100 Watt Plug-In Power To Go MicroSlim AC/USB Power Inverter
Can I connect vacum cleaner big one with Black & Decker 100 Watt power inveter
Posted by dala2k on
Kelly
  • 3,740 Answers
The answer is NO. Your vacuum will draw close to 1200 Watts when you start it and you can write of the inverter being useful after that. You need at least a 1500W inverter for a vacuum. Depending on the Vacuum cleaner motor size that may still cause the inverter to auto shut down or blow the fuse during initial start.
Kelly
Posted on Apr 22, 2010
D. Floyd Kolb
  • Black & Decker Master
  • 43,501 Answers
No,
You will need a much larger power inverter than that to run that vac...
heatman101
I have a black and decker rotary hammer drill i can only read 3 numbers of the model it is 045 but its the last three sn number 0481121 under pat 3309541 need parts manuel for
Before the invention of the hammer drill, people face a lot of trouble drilling in the tight spaces. They had to break down the parts in smaller units in order to drill it properly. But, now the time has changed and the users can easily drill on a portable manner. But, one might wonder, what makes the best hammer drill
? The answer is being more and more complicated each year with so many brands on the market.
The market offering is huge and most of the brands are continuously reinventing their products. We have analyzed many different drills from cordless hammer drill to a corded hammer drill, to hammer drill machine to cordless hammer drill drivers. Thus, we have come up with these top picks.
Dec 25, 2016 | Rotary Drills
100 watt inverter blowout new fuse and keeps on blowing it out does it still work
Fuses blow because of excess current flow so check for shorted wiring or correct connection in the plug. Are you connected to something that is drawing more than 95 watts as that will overload the unit and blow fuses.
Feb 11, 2013 | Black & Decker 100 Watt Inverter...
How do you change the fuse?
Most devices like this have the fuse inside the plug that goes into the cigarette lighter. The knurled silver tip unscrews. Caution that you don't loose the spring inside.
May 19, 2010 | Black & Decker Black Decker PI100AB 100...
I have a vector 3000 watt inveter red fault light is on, wont power a 6.5 amp fuel pump
Check that ground is correctly connected. If nuetral is provided, ensure it too is connected. Your total load is 780 watts. Check power in and ground out of the supply side. There may be a fuse in the inverter on the output side also, replace if necessary. If fault light does not go out after these checks, you will need to contact Black and Decker who manufactures the vector series now.
Jan 16, 2010 | Vector Power Inverter - 3000 Watt
Describe your Black &
I have a black and decker 100 watt power inverter. When the led turns red you are ethier overloading it or it overheated. to fix it unplug it and let it sit for 5 minutes. Plug it in. Plug in an item rated for 100 watts or less. Or try to charge somthing on the usb port.
Aug 23, 2009 | Black & Decker 100 Watt Plug-In Power To...
Describe your Black & Decker Power To
No. You will need typically 35-40 watts for a LCD monitor. 20 watt may not even run DVD's on your laptop. Look for something 80 watt or so.
Jul 07, 2009 | Black & Decker Power To Go Cordless AC/USB...
I want to Register my new Black & Decker GH1000 Trimmer/Edger (Grasshog)
Roy Hollandsworth june 27 2009
I Want to Register My New Black And Decker 18 Volt Cordless Trimmer model HST2018
Jun 27, 2009 | Black & Decker Power To Go Cordless AC/USB...
Black & Decker 100 Watt Plug-In Power To Go MicroSlim AC/USB Power Inverter Logo
132 people viewed this question
Top Black & Decker Electronics - Others Experts
Sheldon Dedek
Vernon Taylor
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
