Question about Acer Aspire 3690 Notebook
Acer aspire 3690 the right half of my screen is black/white/lines
Acer aspire 3690 the right half of my screen is black and white and has vertical lines. I have checked the connection from the mother board, wiggled the wiring between the board and the screen. I connected the laptop to an external monotor and the extra monotor is normal.I can drag windows through the bad side to the external second screen, i just can not see anything in that half.
    Problem Solver:
  • 13 Answers
It sounds to me like your screen has gone and needs to be replaced
Posted on Aug 03, 2010
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Acer aspire 3690 has pink screen in lower half toward middle of screen
Your screen inverter is going bad, you will need to replace the screen inverter. You can parts on ebay, and you may need to take your computer apart to get it replaced.
Jan 30, 2011 | Acer Aspire 3690-2196 Notebook
Acer aspire 3690, screen all black. haven't dropped
you have a video card dieying call acer and get thier trouble shooting tools to help locate the problem.
Jun 27, 2009 | Acer Aspire 3690-2196 Notebook
Wifi main wire, white or black?
White is Main
Black Aux, will work with out, but better to connect, so connector will not short out motherboard.
May 22, 2009 | Acer Aspire 3690 Notebook
Acer Aspire 3690 remove the screen
There screws all around the lcd that are hidden by black rubber / plastic.
Examine the plastic and you'll see them. Pop them off with a straight blade screwdriver.
Then just unscrew all the screws. Most use only 4-6 screws.
Once they are all out. Carefully pull the plastic housing off with your hands. You shouldn't have to use much force so try to be gentle.
Afterwards you should be able to take it from there. There will be brackets holding the lcd in place.
Take those out and then remove the lcd cable from the back of the screen and the inverter from the bottom portion of the lcd.
Swap the lcds and put everything back together.
That should do the trick.
Let me know if you get stuck.
Feb 24, 2009 | Acer Aspire 3690-2196 Notebook
Pink lines on screen
Yes, replacing the screen is extremely difficult, and not recommended if you have no prior experience.
First check that the video adapter is properly attached. Forget about what the tech told you. I would recommend trying a different repair shop, or you can try the "Repair Service" box at the right side of this dialogue box. Just enter your zip code, and it will locate repair services in your area. This is definitely fixable.
Jun 24, 2008 | Acer Aspire 3690-2196 Notebook
Acer Aspire 3690 Notebook Logo
1,111 people viewed this question
Ekse
Steve Sweetleaf
Steve Sweetleaf
Gustavo Ortiz
Gustavo Ortiz
