Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
HI I HAVE SONY TRINTRON TV I NEED TO RESET THE TV
HI I HAVE SONY TRINTRON TV I NEED TO RESET THE TV BECUSE THE TV GO OFF BY SELF IN ABOUT 10 SECOND AND RED LIGHT IS JUST KEEP BLINKING I HOPE ANYONE CAN HELP ME WITH THAT AND I DONT HAVE REMOT ALSO THANKS.
Posted by omatulpatel0 on
atelier mj
  • 70 Answers
I already seem this on that model and it was a short diode D503 part # BY228GP.
Posted on Apr 22, 2010
Need to know which optocoupler ic is used in str 6267 based power supply in sony trintron crt tv
Sony FD Trinitron WEGA... Repair Questions - Fixya
www.fixya.com/.../p228979-sony_fd_trinitron_wega_kv_36fv310_36_t...
Hello, i have a sony FD Trinitron WEGA #KV-36FV310 ... Need to know whichoptocoupler ic is used in str 6267 based power supply in sony trintron crt tv.
Sony KV-TG21M61 21" TV Repair Questions,... - Fixya
www.fixya.com > Forum > Standard (CRT) Televisions > Sony
Need to know which optocoupler ic is used in str 6267 based power supply in ... My sony crt Tv totally dead when touch any components and the IC strs6307 ...
Tv code hi i'm looking for a 3 diget programming code for my ...
Dec 21, 2015 | Sony Televison & Video
My sony trintron 21" the bottom half is black i
solution
step 1 : Now at first test your fly back transformer
step 2 : A.C. transformer out put voltage test
step 3: Vertical yoke coil adjust
Jul 30, 2011 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony Trintron 36 tv won't turn on blinks 6 times
hi
low voltage overload A or B board ic 6007 defect
Oct 06, 2010 | Sony Televison & Video
I have replaced the lamp block and now the power stand by red light is going on and of (this was a new lamp block). Do I need to reset some how?
If standby red light is blinking 3 times after three second pause then check lamp cover that has no been fixed in its place correctly, it is first thing that you removed from tv cabinet to replace lamp, make sure lamp cover is back in place properly and tight.
If standby red light is blinking more or less then 3 times, let me know to diagnose problem.
Thanks.
Sep 04, 2010 | Sony KDF-E42A10 42 in. LCD Television
Sony FD Trinitron WEGA Tv - LAMP blinking 11 times
Sony tv has self protection program. The red Led blinking light indicate the probable cause location. For this model it is either 2,4 or 5 flashes every 3 second. Please check the blinking again
Feb 09, 2010 | Sony FD Trinitron WEGA KV-27FS120 27" TV
It turn off it self
Hi
Thanks for using FixYa. Red light blinking 6 Times means no Horizontal (H STOP), no raster, and so the set goes to the blinking self-diagnosis function immediately. You’ll need to open the back off the TV and check C515 & 516 and the jungle IC, IC206. If you want to do it yourself all this is only recommended if you have electrical expertise and know how to solder/re-solder components if not then you should always contact a qualified repair tech. for the same.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 29, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have a 36" Sony FD Trintron won't turn on and no sound
Have you tried unplugging it from the wall for a couple of minutes, this may reset it.
Jul 26, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
I have a Sony Trintron also - similar model to the
looks like a horiz.output transistor is shorted.check it...
Jul 08, 2009 | Sony KV-32S45 32" TV
NEED OWNERS MANUAL FOR REPROGRMMING CHANNELSKV2185P
I didn't solve problem Ineed a owners manual for sony trntrn tv kv2185p
May 27, 2009 | Sony KV-27S42 27" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
391 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
