from 3,400 to 7,500 depending on whether it has a towing package. more information would be needed for an exact answer. such as year, model, engine , and transmission. and of course, if it has the package.
This is a case for 3.5" HDD that make any 3.5" HDD become external Drive. Here's the product description from Amazon : The CoolMax HD-360-U2 USB 2.0 3.5" External Hard Drive Enclosure is portable size and excellent quality. The 3.5-inch hard drive aluminum external enclosure is specially designed for high capacity hard drives. And its aluminum material design is great for heat dissipation, so you don't need to worry about your hard drive overheating anymore. The HD-360-U2 Series gives you the freedom to work anywhere, no matter if you're in the office, at home or on the plane. This portable 3.5" HDD external enclosure provides maximum durability, flexibility and portability with various interfaces. Once you download your information to the HD-360-U2 series, you can connect it to any system and gain access to your programs and data files anywhere. With built-in hot swap technology, you can connect and disconnect the drive any time.
Features
Supports high speed data transfer rates up to 480/400 Mbps
Fully compatible with 3.5" IDE 133 HDD
Soft-start for slow turn-on feature prevents high inrush currents when initially powering capacitate loads
Anti-shock design, protect the hard disk from damage when moving it
by dimensions do you mean the physical size or the capacity in BTUH? you should get a machine that will fit in your window and if the A/C cooled the room ok get one that matches the BTUH output.
This information can usually be found on a small plate welded or glued onto the side/rear of your A/C units along with the model & serial #s. Although it would be a highly illogical place to put this plate, you may also want to check the bottom but if you turn the unit upside down, do not turn it on for 24 hours, as the gas & oils will be displaced & you can kill off the compressor by doing so.
