Question about Samsung LN32A330 32 in. LCD TV
I have a Samsung 32" LCD Series 3 330. Signals come from a cable service through a set top box connected to the TV with a HDMI1 cable. Only ugly and misplaced Closed Captions are available from the set top box, so I would prefer to use the captions from my TV. However, when I use the TV controller to ask, for captions, the TV replies "Not Available" My cable company is Mediacom. The cable company set top box is from Motorola.
Posted by cmaal on
Anonymous
    Guru:
  • 416 Answers
CC is not passed by HDMI. You have to either use the cable box CC feature or connect the RF cable directly to the TV.
Posted on Apr 22, 2010
I have 32" hand spree TV hooked up to satellite box with a cable connected to the hdmi 1 port. Problem locking to hmdi1 port
Check in the menu of the tv do there is any option to select the input source. If so the select there its to hdmi 1. after that turn off the tv and ON again and check do it go back to TV mode.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 24, 2016 | Hannspree XV32 32 in. LCD Television
My samsung lcd tv stuck on bbc 1 on mono it wont go off screen
pl.see whether the other channels were locked inadvertently 2)if you have set top box remove the connection and connect the cable to antenna slot if you could change channels set top box is defective other wise tuner problem
Feb 18, 2015 | Samsung LN32A330 32 in. LCD TV
I have a Samsung LE40S8 tv. When connecting my
Do you have any further details on your Telergy Set Top Box, Model No. so I can look into this for you.
Jul 08, 2011 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
SAMSUNG UE32B6000 have problem with conecting ,it say weak signal,or no signal just blank screen, where do i start,
If you just have over-the-air signals from local broadcast stations, you need a good VHF/UHF antenna connected to the RF input jack on the TV in order to get reception. If you have access to cable TV or satellite, you need to connect the box or receiver set-top-box to the TV using a HDMI cable. You need to select on the TV using the remote, (press the MENU button) setup for tuning channels. Do a scan after setting to AIR or CABLE so the TV picks up all available channels you can get. Once this is done you can change channels and see TV. If you reply back with specifics, I can help more...
Mar 29, 2011 | Samsung UE32B6000 32" HDTV-Ready OLED TV
Cable is connected to HDMI1. When Tv is turned on, the screen is corrupted/distorted. Color is messed up, wavy vertical lines, from middle of the screen down. But there is sound. What is wrong/ how can we...
Try first by using another port. Select HDMI2 and select proper "Input" from remote. If you get the same results, cheap HDMI cable. Replace it. If it is only on HDMI1, then there is a problem with the contacts. Warranty or just use HDMI2, 3 or 4 etc. Worse case senerio, you can use the 5 cable component cables as they can also carry HD signals.
Jun 29, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Samsung LN22C350D1D FACTORY SETTINGS??
1. Do what you did, enter to service mode, and reset to factory default.
2. Use the component cable (green, blue, red, white, red) connect your set top box to the TV’s component input.
May 10, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I have Samsung 360 Series 3 LCD using Fiber audio cable directly from cable box to television...not getting audio...checked all cable box settings...unsure...Do have alternatives in house to test box and...
As I see it this TV has no optical digital audio input. The connection on the rear of the set is "Digital Audio Out (Optical)", not in. I think you need to run a HDMI cable from the cable box to the TV to get digital audio.
Nov 05, 2009 | Samsung LN32B360 32 in. LCD HDTV
I have a Samsung LCD HDMI 37inch TV series 5 do I need a set top box
You have a really nice TV, you have a built in ASTC tuner(digital).
If you want to recieve OTA(over the air) signals, all ypu will need is an antenna.
Visit this site for some great info on digital TV.
http://www.antennaweb.org/aw/welcome.aspx
Let me know if I can provide further assistance
Please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Apr 16, 2009 | Samsung LT-P1745 17 in. EDTV-Ready LCD...
Samsung series 6 LCD no video output!
Try connecting your DVD recorder directly to the source (satellite/cable box) and then to the TV.
Feb 25, 2009 | Samsung TXN3245FP 32" TV
Can't get the Samsung HT-z310 Home Theater to stay on AUX2
you need a fibre optical cable for this, simply you connect that from your dvd to tv and then set the input on the dvd to digi in. i have exactly same home cinema system.
Nov 27, 2008 | Samsung HT-Z310T Theater System
Samsung LN32A330 32 in. LCD TV Logo
318 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
