We have had this Frigidaire 2 years. When I push the wash button, it lights up, but when I push the drying selection it won't light up . Even when I push the start button it won't start. If I close the door the readout shows 93 milutes, but after a few moments the light goes off. Can you help me? Thanks.
Model number would help alot!
to locate...Open your Frigidaire dishwasher's door and check the inner frame -- left top corner and the left and right sides --for the product label containing the model number.
or Check the inside of the door frame if you don't find the number on the inner frame.
let us know. thanks!
SOURCE: Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
SOURCE: dishwasher, flashing lights, frigidaire
The steam has gotten into the keypad display and fried it. Call Fridgidaire and let them know you've seen numerous people on the internet with the same problem and that you need part# 154554401 It worked for me.
SOURCE: My Frigidaire dishwasher will not start.
WOW! This same thing is happening to me tonight too! The Lock button is lit for me but not the "heat dry". Looking forward to reading what this problem is.
SOURCE: Frigidaire Dishwasher FDB1050REC1 - Washing Indicator Light Blinking
Here is what happened, you pulled the door open without pressing cancel and allowing it to pump the water out, hence the "flooding in the bottom". This is just one reason why it maybe blinking, there is a water sensor in the bottom. If your dishwasher is hooked up properly to any decent garbage disposal, run the disposal for about 30 seconds to a minute. This should pump the water out, more like activate a light siphoning affect. It should work as normal. If you are not having luck with that, detach the DW drain get it low and let it siphon.
SOURCE: I have a Frigidaire Gallery
Have you tried unplugging the dishwasher for a while then .. Trying it again.. If the problem still persists have a cleaning done to the control board and touch pad inside and if still the problem persists then i doubt whether the problem is that the control board has failed...
I appreciate your post, friend!
I understand that the clean, wash, and dry buttons on your Frigidaire dishwasher are blinking along with the four LED light. This appears to be a delay start cycle. I would recommend pressing the cancel button. If that does not clear the lights you can perform a reset and to do that you would need to disconnect power from the dishwasher for roughly ten minutes. I hope this is helpful. -Matt
Thank you for your post, Patrick Chow!
From my understanding your Frigidaire dishwasher is getting stuck in the washing cycle. Sounds like you may have a possible issue with a sensor or control panel. I would suggest performing a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for approximately ten minutes. If you continue to experience problems with you dishwasher not cycling I would recommend reaching out to a technician for a diagnosis to be completed. The technician would be able to pinpoint the cause of the failure and complete repairs. Hope this is helpful. -Matt
Turn off the dishwasher and unplug it from the power supply. Wait 10 minutes and restore power.
Select a "Hi Temp" wash cycle, followed by a heated dry setting on the dishwasher.
Repeat step 3. This will reset the dishwasher.
