The USB streaming driver for the Camcorder
is not available for Windows Vista OS from Sony at this point. Hence it is not
possible to transfer videos using USB interface. You may use i.LINK or A/V
interface to transfer videos from the Camcorder to the Computer which is
running on Windows Vista Operating System.
Please follow the steps to transfer video to a computer using an
i.LINK connection (IEEE 1394).
IMPORTANT: Video capture software and a compatible video
capture card must be installed on the computer. Depending on the computer
manufacturer, various video capture cards and software (Adobe Premiere, Roxio
Video Wave, Microsoft Windows Movie Maker, etc.) may be available or already
installed on your computer. If necessary, contact the manufacturer of your computer
for further information.
NOTE: Many Sony VAIO computers are bundled with Sony DVgate
Motion or DVgate Plus software for video capturing. Some VAIO computers also
include Click To DVD software that will allow video capture to the computer
hard drive or directly to a DVD.
i.LINK port.
NOTE: The computer i.LINK ports
and capture cards may have either 4-pin or 6-pin connections. Sony digital
camcorders use i.LINK ports with 4 pins. If your computer only has a 6-pin
i.LINK port, then it will be necessary to use a 4-pin to 6-pin i.LINK cable.
It should now be possible to
copy the video using the video capture software if the computer hardware and
software are configured correctly.
The USB streaming driver for the Camcorder is not available
for Windows 7 OS from Sony at this point. Hence it is not possible to transfer
videos using USB interface. You may use i.LINK or A/V interface to transfer
videos from the Camcorder to the Computer which is running on Windows 7
Operating System.
Please
follow the steps to transfer video to a computer using an i.LINK connection
(IEEE 1394).
IMPORTANT: Video capture software and a compatible video capture card must
be installed on the computer. Depending on the computer manufacturer, various
video capture cards and software (Adobe Premiere, Roxio Video Wave, Microsoft
Windows Movie Maker, etc.) may be available or already installed on your
computer. If necessary, contact the manufacturer of your computer for further
information.
NOTE: Many Sony VAIO computers are bundled with Sony DVgate Motion or DVgate
Plus software for video capturing. Some VAIO computers also include Click To
DVD software that will allow video capture to the computer hard drive or
directly to a DVD.
i.LINK
Cable.
i.LINK
port.
NOTE: The computer i.LINK ports and capture cards
may have either 4-pin or 6-pin connections. Sony digital camcorders use i.LINK
ports with 4 pins. If your computer only has a 6-pin i.LINK port, then it will
It should now be possible to copy the video using
the video capture software if the computer hardware and software are configured
correctly.
Operating System.
Please
(IEEE 1394).
information.
directly to a DVD.
correctly.
i.LINK Cable.
i.LINK port.
Operating System.
Please
(IEEE 1394).
information.
directly to a DVD.
correctly.
Camcorder is not available from Sony at this point. Hence it is not possible to
transfer videos using USB interface. You may use i.LINK or A/V interface to
transfer videos from the Camcorder to the Computer which is running on Windows 7 Operating System.
using an i.LINK connection (IEEE 1394).
information.
directly to a DVD.
i.LINK
Cable.
i.LINK
port.
correctly.
Operating System.
Please
(IEEE 1394).
information.
directly to a DVD.
i.LINK
Cable.
i.LINK
port.
correctly.
for Windows Vista OS from Sony at this point. Hence it is not possible to transfer
videos from the Camcorder to the Computer which is running on Windows Vista Operating System.
Please
(IEEE 1394).
information.
directly to a DVD.
i.LINK
Cable.
i.LINK
port.
correctly.
The USB streaming driver for the Camcorder is not available for Windows 7 OS from Sony at this point. Hence it is not possible to transfer videos using USB interface. You may use i.LINK or A/V interface to transfer videos from the Camcorder to the Computer which is running on Windows 7 Operating System.
Please follow the steps to transfer video to a computer using an i.LINK connection (IEEE 1394).
IMPORTANT: Video capture software and a compatible video capture card must be installed on the computer. Depending on the computer manufacturer, various video capture cards and software (Adobe Premiere, Roxio Video Wave, Microsoft Windows Movie Maker, etc.) may be available or already installed on your computer. If necessary, contact the manufacturer of your computer for further information.
NOTE: Many Sony VAIO computers are bundled with Sony DVgate Motion or DVgate Plus software for video capturing. Some VAIO computers also include Click To DVD software that will allow video capture to the computer hard drive or directly to a DVD.
Connect the other end of the i.LINK cable to the computer.
NOTE: The computer i.LINK ports and capture cards may have either 4-pin or 6-pin connections. Sony digital camcorders use i.LINK ports with 4 pins. If your computer only has a 6-pin i.LINK port, then it will be necessary to use a 4-pin to 6-pin i.LINK cable.
It should now be possible to copy the video using the video capture software if the computer hardware and software are configured correctly.
Determine what kind of video line-in connection the TV has. These connections are typically on the back or side of the TV. You also will need to determine what kind of video line-out connection the computer has.
Types of video connections include S-Video, VGA, DVI and HDMI. The Resources section of this article offers links to sites that will help you identify the connection type of your TV and computer.
Purchase a video connection cable that is for the type of connection that the computer and TV share. For example, if the TV and computer both have S-Video ports, you should purchase an S-Video cable. S-Video connections are the most common and least expensive option.
Connect the end of the S-Video cable that matches the connection on the computer to the computer video line-out port. Connect the other end to the video line-in port of the same kind on the TV.
Convert video from VGA video to S-Video or even component video. Do this if the two connection ports on the computer and TV are not compatible. You will need to purchase a scan converter box, a VGA video cable, and either an S-Video or component video cable. Connect the cable that will connect to the computer jack to the computer and the converter box, and connect the S-Video or component video cable to the TV and the converter box.
Turn on the TV and use the remote control to select "Input." Some TVs will have multiple selections. Turn on the computer and play a movie or display an image on the screen. As you are scrolling through the "Input" options on the television, you will see a matching image of what you opened on your computer on the TV screen when the correct input is selected.
Adjust the screen resolution on the computer if the image on the TV is distorted, too small or too large. Do this by going into Control Panel and Display Settings on the computer. Select a different screen resolution until the image on the TV fits the TV screen
