Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
Wiring an electric water heater
Just bought a kenmore power miser electric water heater and it came with two elements and three wires (blue, black and yellow). I only have two wires coming out of the wall (white and black). It is a 220 system for the water heater as i checked and have 120 coming from both wires. Do I hook up both the black and blue from water heater to the black out of wall and the yellow to the white?
Christopher a Martin
  • 455 Answers
Hello,You are correct! Black/blue=black & Yellow=white 220volt single phase power.There are 3 wires for 3 phase power connection NOT the case in a home.Also an "off peak"timer option would use (black) only controlling the bottom element and (blue) controlling the top element.
Posted on Apr 21, 2010
Testimonial: "thank you I finally have hot water!!!!!"
Rheemglas standard energy miser electric water heater model #81vr-80 gal serial #RH0501c00664. Does it have two heating elements and where are they?
it does have 2 elements they are located under the 2 panels on the heater you will find them under the covers on the front they will be connected to the thermostats follow the wiring. besure to turn off the power before working on it and use a tester to double check
May 31, 2014 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water Heater Issues
top element fried unless temp was met at time of test
Apr 28, 2017 | Water Heaters
How to wire a rheem 40 gal electric hotwater heater with a yellow,blue, and Black wires
Jan 2013
1) Water heaters can be wired many different ways.
Copy following link For ordinary household 240Volt water heater, the heater is wired for non-simultaneous operation:
http://waterheatertimer.org/images/WH-w-combined2-1000.jpg
Copy following link For other wiring diagrams, including off-peak, simultaneous, redundant, etc
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
2) Make sure water heater circuit breaker and wire size matches watt rating that shows on end of each element.
http://waterheatertimer.org/Color-codewire.html
3) Non simultaneous means only 1 element is ON at a time.
So either upper element is ON, or lower element is ON, or both elements are OFF.
Both elements are never ON at same time.
So non-simultaneous water heater with two 4500 watt elements has total connected watt rating of 4500 watts. Because only 1 element can be ON at a time.
Use 30 amp breaker and 10 gauge wire.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 19, 2013 | Rheem RUUD ELD40 Water Heater,electric,40...
We purchased a new electric hot water heater we installed it on a 220 line and we are not getting no hot water
check with a vom set on high voltage setting. for power... black wire to black wire,, white wire to red wire on heater ground wire to tank ..on 220v there is no neutral like on 110volts..check red reset button under top panel / control push on it resets it,,,
Apr 17, 2011 | Whirlpool Water Heaters
I just installed a new electric water heater with dual high limit elements.I hooked up the red and black wire, just like the old one and set the limits to 125 and turned on breaker. we waited about 6hrs...
Most water heaters heat the water on top first. This is because the warm water will rise to the top and the hot water is drawn off the top. When the upper thermostat turns the top element off then the bottom one comes on. It makes it sound like there is a problem with the top element. Disconnect electric, and read the resistance on the element terminal to terminal. If it shows open the you have a bad element. Did you make sure the heater was completely full before turning the electric? You must run the hot faucets to remove all the air from the top of the tank before turning on the electric. Elements will burn out quickly if out of the water.
Nov 09, 2010 | RELIANCE ELECTRIC WATER HEATER
I replaced the heating elements(2) and switiches(2) on my Rudd electric hot water heater. Model PES 40-2. The switghes came with several wiring diagrams.(universal) Can I get a diagram specific to my...
Residential water heaters USUALLY follow same diagram unless water heater is wired for other purpose. Multiple diagrams on instructions show available options. Take photo of wiring before removing wires on any electrical device.
Upper element.
Black wire from top of heater connects to #1 top left screw.
Red wire from top connects to #3 top right screw.
Blue wire from upper element connects to #4 middle screw on right side
Red wire from lower element connects to #4 middle screw on right side
Yellow wire from upper element connects to #2 lower left screw
Black wire from lower thermostat connects to #4 lower right screw
Upper element: Yellow and Blue wires connect to either screw
Lower element: Red wire from top connects to either screw
Lower thermostat: Black wire from top connects to top screw
Short wire between lower thermostat and lower element
http://waterheatertimer.org/images/Water-heater-wiring-w-numbe.jpg
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
Sep 18, 2010 | Whirlpool Water Heaters
I installed kenmore power miser heater not getting hot water need to know if wires are correct please
Water heater are usually 240 volt. I do not know if this is a standard water heater (tank type) or a tankless but the main wiring will be the same. Black should go to black and the the red to the white if you do not have corresponding red wires. The green is the ground and should be attached to the screw in the wiring box of the heater. If you have any other questions please contact me at [email protected]
Jul 31, 2009 | Water Heaters
Water heater- not always hot
common problems i have seen are:
1) wife or kids hitting the OFF switch thinking its the light switch in the closet where my heater is located.
2) heating element has died. you should have 2 elements in this heater. when one dies, the heater cannot keep up with the demand of heating 50 gals of water.
if there is a warranty, then now is the time to exercise it.
if no warranty, then it is possible to troubleshoot each element to see which one is dead if you are handy with a voltmeter and electrical wires. if comfy, i can provide steps to narrow it down. list the kenmore model number if you reply.
Feb 02, 2009 | Intermatic WH40 - Water Heater Time Switch...
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
399 people viewed this question
Top Rheem Water Heaters Experts
Bill Johnson
jdthefixer
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
