Got a samsung r610
i had a bios password on it [which i know] but i wanted to remove the need for bios password
so i went to the change password bit and when it said enter password i just hit the return key
now i cant get passed the 'password'
i rang samsung who can fix it but want proof of purchase
i bought it new from argos but
as i did it online i got no reciept i rang argos who gave me the purchase ref no but samsung wont take this!
rather than writing to my credit card co for proof is there a easy way to fix this
To break the bios password is no problem.
All you need to do is just to power off your laptop and remove the battery.
Get a screw driver to unscrew all the screw that will lead you to your laptop board. When you get to the board, remove the cmos battery and try to screw your laptop back, put your battery and power on without the cmos battery, leave for sometime to power up, your bios will go back to default and will never ask for password again.
After it has stay for a while, you can now unscrew back and put the cmos battery.
Makesure you screw back all the screws from where they are been removed.
After all this you can enjoy your laptop and still set the bios password if you want.
Please if you cannot do all this yourself, get someone who can help or a repairer in other not to complicate issues.
Take care.
Just visit http://www.bios-password.kickme.to/
They provide a Samsung Bios Master Password unlock and removal Service. I got a working password within minutes.
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
