Question about Hunter 30547 Air Purifier
I purchased a Hunter Purifier, model 3057, about 9 months ago and was working fine. Now, filter and pre-filter is constantlt blinking on the unit. Does this mean I need to replace both of the filters or can they be cleaned and vacuumed.?
shafi
    President:
  • 1,070 Answers
Hello Sir,
It Seems To be Damaged...So try to Do following.....
  • Locate the air purifier's filter. Many times this is located underneath and toward the back of the air purifier. Note where it came from and what direction it was placed in the air purifier.
  • Carefully pull out the filter. Place disposable filters in a plastic bag and take them to a store for comparison and find the exact replacement filter. If it's a reusable filter, clean gently with warm water and mild soap. Rinse thoroughly until all suds are out of the filter. Shake out the filter to remove any excess water. Set the air purifier's filter aside when finished.
  • Disassemble the air purifier as much as possible. Make sure you keep track of what you are doing so that putting it back together is easier. You may want to take notes for easier assembly later.
  • Use a damp cloth wet with warm water to wipe down the entire purifier and all its parts. Wipe out all the grooves really well.
  • Leave all the air purifier's parts on a clean surface to dry completely. This may take several hours, depending on the consistency of the filter.
  • Reassemble your air purifier once it is dry. It is now clean and should be working properly.
Hope this Make you Better...Thanks For Contacting FixYa...
Posted on Apr 21, 2010
Heath Moyer
  • 767 Answers
The filters can be cleaned with a vaum. Then hold the filter button down for 60 seconds and the light wil go off.
Hunter hepatech 40882 uvc air purifier won't turn after cleaned filters
Hello, this is Ava with Think Crucial.
Filter life counters should be reset each time the filter has change. If your air purifier has a reset button, press and hold the reset button until the lights go out. You may also unplug your unit from the power for 30 seconds before plugging it back on if your unit doesn't have a reset button.
You can purchase a wide variety of high quality Hunter replacement parts for your Hunter Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=hunter
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Oct 24, 2016 | Hunter Air Purifiers
Tip
How to Reset Your Air Purifier Filter Light
<span style="font-weight: bold;">Airgle Air Purifier:</span><br /> <ol> <li>Turn off and unplug the unit </li> <li>Press the light button to the "on" position </li> <li>Plug in the unit, and then release the button after the Filter-check starts</li> <li>The system will automatically reset the Filter-Check Gauge in about 25 seconds</li> <li>Once the procedure has completed resetting, please turn on the unit and press "Filter Check" button again.</li> <li>This time, the system should report an accurate result. </li></ol><span style="font-weight: bold;">Alive Air Purifier:</span><br /> <ol> <li>Insert a straightened out paper clip into the reset hole, with the unit off, and push the Timer button.</li> <li>You should hear a 2 beeps, signaling that the Reset was successful.</li></ol><span style="font-weight: bold;">Holmes Air Purifier:</span><br /> <ol> <li>Units which have an indicator light must be reset once the HEPA filter has been replaced. Reset indicator by inserting a small object (such as a pin or paperclip) into the hole marked reset.</li></ol><span style="font-weight: bold;">Honeywell Air Purifier:</span><br /> <ol> <li>Reset the filter indicator by pressing and holding the "Filter Monitor" button until the indicator light shuts off.</li></ol>or<br /> <ol> <li>With the unit powered on, press and hold the appropriate filter<br />indicator button down for approximately 10 seconds until the<br />light turns off.</li></ol><span style="font-weight: bold;">Hunter Air Purifier:</span><br /> <ol> <li>Change the filter and/or pre-filter.</li> <li>Now, you must choose which counter you want to reset. Press and hold the filter reset key (approximately three seconds) until the prefilter indicator flashes. Press and release the reset key again to alternate between the two indicators. The counter that will be reset is designated by the flashing indicator. For Models 36394 and 36395: Use the tip of a pen or pencil to press the key.</li> <li>Once you have the correct indicator flashing, press and hold the reset key for three seconds to reset that counter to zero hours. The indicator will stop flashing when it has been reset. If needed, repeat these steps to reset the other counter.</li></ol><span style="font-weight: bold;">IQAir Air Purifier:</span><br /> <ol> <li>To reach the Filter Life Reset function from the main display window, press the Menu key seven times.</li> <li>Press and hold the Enter key until the flashing cursor appears. Release the Enter key. The first filter selection to appear is the Pre-Filter.</li> <li>Press the Up Arrow key to select the filter that has been replaced. The Filter Life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key to confirm that the selected filter has been replaced. The filter life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key one more time to confirm the filter change or to exit without resetting the filter life, press the Menu key (M=Menu).</li> <li>Upon successful reset of the filter life, the new remaining filter life (taking the currently selected fan speed into account) will be displayed, and the filter LED light on the control panel will change from red to green.</li></ol><span style="font-weight: bold;">Kenmore Air Purifier:</span><br /> <ol> <li>Press the FUNCTION and OFF TIMER buttons at the same time for five seconds. The CHANGE FILTER INDICATOR will flash five times and turn off </li></ol>
on Jun 17, 2011 | Air Purifiers
Tip
Air Purifier Cleaning
You bought that air purifier to help to clean the air in your home. However you have forgotten about it and now you expect it to still clean, when all of the cleaning surfaces and the filter that catches the big chunks are completely used up and covered with dust and dirt.
Here is what you need to do on a regular, like monthly, basis to keep it working well.
  1. If your unit has a filter or pre-filter pull it out and wash it gently in some warm soapy water. If the filter is a throw away one then place it in a plastic bag and dispose of it. Be careful not to throw it away before you make sure you know what to get to replace it. You may need the old one for comparison when purchasing a new one. Also take note of how you removed it and the direction of the air flow. Some of the filters are made to have the air flow in a certain direction. The filter is often located in the back side at the bottom of the unit.
  2. Take apart everything that you can on the air purifier and clean all the pieces with a moist cloth. You may need to take toothpick or something small to clean out the small grooves and crevices in the unit.
  3. Leave everything dry completely before reassembling the unit. This may take quite a while for some of the filter media. A few hours is not uncommon, be patient.
You now will have your air purifier working in top condition again
on Jan 11, 2010 | Air Purifiers
Hunter air filter when you turn it on it keeps cycling- on/off,on/off and wont stay on. also hepa filter button not working any more, does not light up blue when pressed. TY for any help : )
If your unit has a reset button, try resetting your unit. Also, replacing the filters and resetting it after putting on the replacement filters usually works. If this fix doesn't work, I suggest you contact Hunter support for assistance and their number is 888-830-1326.
Ava B.
Oct 01, 2016 | Hunter Air Purifiers
I have a hunter air purifier model number 36316 and need to know how to change the filter
To change the wick filters of your humidifier:
1. Turn off the unit and unplug it from the wall outlet
2. Remove the tank for the housing.
3. Locate the 3 lock tabs in the base of the unit. Turn them clockwise until the base of the tab lines up with the indentions in the base and lift off the housing.
4. Locate and turn the lock tab clockwise on the base holding the wick fram. Remove the wick frame and set it aside.
5. Remove the old wick by pulling the bottom of the wick out of the frame first and discard.
6. Insert the new wick top first. Ensure wick is in between the tabs at the top of the wick frame then slide the bottom part of the wick into the fram, making sure not to crush the bottom corners of the wick.
7. Reassemble the unit and refill the water tank if necessary.
8. Turn the unit back on and resume operation.
http://www.thinkcrucial.com/search?page=1&q=hunter&type=product
Ava B.
Dec 16, 2013 | Holmes Products HAP422-UC Air Purifier
Hunter Air Purifier making screaming noise
Most likely the problem is a bad bearing in the fan motor.
May 31, 2012 | Hunter Fan Company 30251 Air Purifier
Owner manual for hunter 30747 Air Purifier
You may refer to this online manual for your model number to help you put back the filters in your unit.
Hunter 30747 Instruction Manual
https://www.thinkcrucial.com/search?type=product&q=hunter
Ava B.
May 19, 2012 | Hunter Air Purifiers
Lights still flashing after i replaced filter
You have to press the reset button on some models. The unit does not have any way of knowing you reset the filter -- you have to tell it.
Mar 22, 2009 | Hunter (30067) Air Purifier
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier http://www.fastbrowser.net/netpicker/Filter-lights-on-your-Airifie.htm One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • REPORT ON THE AIR QUALITY CLEAN UP IN OUR OFFICES
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • WHOLE HOUSE HEPA
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • Nov 26, 2007 | Hunter 30216 3-SPEED FLOOR MODEL Air...
    Hunter 30547 Air Purifier Logo
    315 people viewed this question
    Top Hunter Air Purifiers Experts
    Marvin
    Marvin
    Tom Chichester
     Russ Hill
    Russ Hill
    Are you a Hunter Air Purifier Expert? Answer questions, earn points and help others
