Greetings~
I received this camera with no instruction manual. Somehow I got it stuck in the recording mode and want to get out of it (!) - will you please help me to understand how to turn this feature off so that I can resume taking photos.
Also, I am trying to locate the macro feature.
Thank you very much for your assistance!
Shayna
SOURCE: How to disable microphone / sound on Samsung Digimax A503 Camera while recording movie
no i cant even turn the sound on...can sum1 please tell me how you get the camera to record sound when i record a video.thankyou :)
SOURCE: lost manual and need to delete some photos
http://www.retrevo.com/support/Samsung-S500-Digital-Cameras-manual/id/563ag625/t/2/
SOURCE: How do you enable the sound while recording a
i dont think u can i tried a million different things and i searched for a speaker and nothing
SOURCE: My Digimax A503 camera keeps coming up on screen
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera
which can prevent the full power of the batteries from flowing into the
camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with
a dry cloth (heavy corrosion may require cleaning with a wire brush,
steel wool, or sandpaper). Remove any residue that may have fallen
into the battery compartment during cleaning, then wipe both ends of
the batteries and place them back in the camera. This cleaning clears
the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have
a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Testimonial: "Thanks for the info it was that I think, I will be using the camera today so that will confirm it, I have put you in my documents for later reference."
SOURCE: My samsung digimax a503 is showing a flower in the
Switch on camera and select menu. Instead of choosing,"SUNSET", select , "AUTO", then click, "OK".
You should spend some time going through the manual.
Goodluck.
