my AOC L24H898 tv has no picture just sound have tried turning off and back on but same issue no picture just sound.my AOC L24H898 tv has no picture just sound have tried turning off and back on but same issue no picture just sound.
You can't post conmments that contain an email address.
Do you have power surge or failure issues with your electricity? Try plugging your TV into an uninterruptable power supply (UPS) to get line conditioning and the continuous power.
Otherwise, I'd guess there is something else causing memory failures (bad chip or something).
1. Press and hold "Menu" and "Channel +" on the TV. 2. Using other hand, press the power button. 3. A small screen should appear in the top left part of the screen. 4. Using the remote, select "Memory Recall" and select. 5. Power off and re-boot the computer (only if connected to computer) if not goto (6) 6. Run channel auto-scan to regain the picture.
I bought this HDTV for my daughter , she is up at school now.I installed it for her and there were only about 20 channels. even though the system had more the lady at the fron desk told me that they are getting a new system on the 31st so I just left it and expected it to work . but my daughter just called me and said that someone else brought another tv in and installed it on the same cable and all the channels work great. is there anything I can do , is there a switch on the tv somewhere.
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Try this:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
Try this:
A factory reset on several AOC models can be performed by unplugging the TV for 5 to 30 minutes. When it comes back on it should be reset to factory defaults and ask to do a channel scan. You have somehow enabled the so-called childproof or "Bar mode" of the TV which deactivates the panel buttons so kids (or patrons) cannot mess it up.
This sounds like a common problem on these TVs. Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote) 2. Using the other hand, press the Power button. 3. *A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter. 5. Power off and reboot the TV and Computer. 6. Run channel auto-scan to regain the picture.
If this still does not work, perform steps 1-3, but when you get to step 4, select "EEPROM Init". Then steps 5 and 6 to power it off and back on.
This sounds like a common problem on these TVs (it's happened to both of my AOC TVs a couple times). Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote) 2. Using the other hand, press the Power button. 3. A small screen should appear in the top left part of the screen. 4. Using the remote, select "Memory Recall" and Enter. 5. Power off and reboot the TV and Computer. 6. Run channel auto-scan to regain the picture.
According to the manufacturer, to reset the entire unit do the following:
