Question about Dacor ECD230 Epicure Electric Double Oven
I have an ECD230SBK Dacor oven. I need a relay
I have an ECD230SBK Dacor oven. I need a relay board that gives power to the heating element. Is there a service manual available.
Posted by Anil Angelo on
5 Related Answers
Anonymous
SOURCE: dacor convection oven cps127/130 failure code f1
i found my circuit/schematic tucked inside the back panel in a envelope, you have to remove the oven from the wall to gat to it and start un screwing the panels, i think it was on the top.
Posted on Sep 05, 2007
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Dacor model W305 blew an element. Replaced it. Won't work.
The fan and element rely on a supply from the thermostat, so perhaps when the element blew, it damaged the thermostat, another possibility is that there is a fuse of some sort in the oven that has blown as a result of the element blowing.
It is highly unlikely that the fan and element are faulty, you will have to look further.
Plz rate this solution.
Thanks, and merry xmas.
Posted on Dec 20, 2008
Anonymous
SOURCE: after house lightening strike - LCD shows "33"; only oven lights
call your home owner insurance agent
Posted on Jun 18, 2009
Anonymous
SOURCE: My DACOR + ECS 130 covection oven light relay keeps clicking.....
Change your touch pad. The light maintains last condition if you unplug the touch pad while on or off. The touch pad appears to have alot of trouble with respect to the other functions as well. Beware the part#s provided by Dacor do not always match what they installed on their products. Verify the style before purchasing.
Posted on Aug 09, 2010
Anonymous
SOURCE: My Dacor wont heat, broil or convection after self cleaning
like another person stated-from the front behind the door, take off the 6 screws and the cover by the latch. there is an "oven hi temp limit switch" It is crome with 2 heavy black wires connected to it. On the back side of this is a small red button which will reset the limit switch. I had the same issue (everything worked except the any of the heating elements) and quickly resolved.
Posted on Jan 10, 2011
Tip
Dacor Oven Won't Preheat
My Dacor oven ECS227 would not preheat. Most website advice was the High Temp Cutout needed to be reset. That was not my problem. I found a schematic for the oven and determined the relay that controls the power to both the Broil and Bake elements was not conducting. I could hear the relay operate but the voltage for the two elements was not on the output side of the relay. I ordered a new Relay Board (92029) for $200 and after replacing the board the oven worked except it started smoking from the panel area and the smell was that of an electrical overheat. Further investigation revealed one of the slip-on connections on top of the relay was sparking and generating heat in the range of 150 degrees (measured with a IR temperature meter). It was melting the plastic around the connection which was the source of the smoke and the smell. I removed the wire, compressed the connection points a little, reconnected the wire and all is well. The plastic around the connection became very brittle from the heat and broke off while I was working on the wire connection but it still works. I found you can purchase the relay itself for about $5, so I did that just in case this should happen in the future. I will repair my old board and have it ready to go for a future replacement if needed and will also replace the connection clip at that time. The relay can be ordered from Mouser Electronic - their part number 655-T9AP1D22-18-01. The relay is stamped T9AP1D22-18 Potter Brumfield. Hope this helps anyone else when the resetting of the High Temp Cutout does not solve your problem.
on Jun 21, 2015 | Dacor Ovens
Dacor bottom oven not heating
I have a DACOR double electric oven model ECD230SCH. the top oven lower element went out 1 and 1/2 years ago, but the top element broiler works. Yesterday the bottom oven did the same thing- bottom element not working along with convection. Pulled off doors and cut breaker. Checked thermal switch on top off oven- closed good. Pull out element and Ohm'ed out- good. Now pulled over and out oven top panel to get to the control boards. Found a nice set of schematics for the over control boards and electronics. Sat down and pin-pointed both relays that supply power to upper and lower oven "lower" heating elements. these are on 2 different boards- upper over relays on bigger board on the left with the transformer. Lower oven on the right smaller board. Hardest pain in the rear was just getting the little plastic stand offs to push back through the board to get it off. Finally got it off and inspected board. Low and behold the relay I pin-pointed had a burn/open connection on the solder joint. Re-soldered tested oven and lower oven lower heat element works now! Went to the next board and got that off and same exact problem on the rely for the top oven lower element. Re-solder and test- good!! Put everything together and ran over to 350 on top and lower and back to normal. Wife very happy she did not have to pay a repair man big bucks to swap out the control boards- would have had to replace both.
I have a degree in electronic technology so as a technician for many years did low and high voltage component level repairs. But pretty easy and you can visually see the open solder joint on the back of the board at the relay leg.
Jim B Roseville, CA.
Jan 31, 2014 | Dacor Ovens
Dacor 1.5 years old convection oven...not heating
Flip both oven breakers HARD to the "off" position, then back on. If it did not help - you might have a problem with a relay on the control board or a failed bake element.
Grab a flashlight and check the element on the bottom (if you can see it). DO NOT TOUCH THE ELEMENT! If you find any bulging or cracking on the element - it'd out. Before removing the element turn the oven off on the breaker panel.
PS Model number is needed to find the part numbers.
Oct 22, 2009 | Ovens
My upper oven/ convection function on my dacor ecs230b will not heat
Bake and convection bake settings both use the bottom bake element to heat. It would be unusual for bake to work without conv. bake working. You also have pure convection which uses a different element surrounding the conv. fan on the back of the unit. If you press a feature and nothing happens it's the touch pad. If it comes on then turns back off it's probably the ERC (clock). If it comes on and wont heat only in pure conv. possibly an upper relay board or element problem.
Sep 22, 2009 | Dacor ECS230 Epicure Electric Double Oven
Dacor touchpad
HI, this is a Element relay circuit failure. this relay is a separate PCB board with attached relays.
this relay board will need to be replaced.
CLICK HERE TO ORDER
Jul 19, 2009 | Dacor ECD230 Epicure Electric Double Oven
My dacor oven model ECS130SBK is very slow to heat. Sometimes reaching the desired temp. after a long wait. Sometimes it never gets there.
I found the bottom element was not getting any power by using a volt/ohmmeter and a test method described elsewhere. (Shut off power, hold down COOK TIME while turning on power. then within 30 seconds press each mode you want to test and only that element/fan/etc will turn on. Cancels by itself after 30 sec.)
I traced the wire back to the relay (wire checked good) and there was no power getting through the relay although it clicked. Removed the relay board to replace it and found a cold solder joint on the "out" terminal with obvious past arcing carbon. Cleaned and soldered the pin and the oven now works normally.
WHY THE SLOW TO HEAT? The oven turns on all the elements to preheat faster and when it reaches your set temp it beeps and now only turns on the element you selected to maintain the temperature. (Bake or Convection) Our malfunctioning ovens would then cool since the element is not working properly and it must go back into preheat and keep cycling.
BY THE WAY- Don't ever use 4 hours on self clean it kills the boards and/or display. I also put a house fan in front of the oven and blow it into the lower grill to take away some of the heat on the two boards. Learned the hard way!
Jun 08, 2009 | Dacor ECS130 Epicure Electric Single Oven
Dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Oct 26, 2008 | Dacor MCS130 Millennia Electric Single...
Dacor ECD230 Epicure Electric Double Oven Logo
151 people viewed this question
Top Dacor Ovens Experts
Paul Bade
Vincent G
Vincent G
ray gallant
Are you a Dacor Oven Expert? Answer questions, earn points and help others
