Lands Phones Logo
A
Anonymous Posted on Apr 21, 2010
Can't change ring tone on Panasonic KX-TCA175
We can't change the ring tone on our Panasonic KX-TCA175 phone handset. It's stuck on a really annoying melody (internal and external calls) and the manual is no help. Any answers out there gratefully received!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 28, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
659
Points
I had the same problem. I was advised by Panasonic support that the PBX system needed a firmware upgrade to solve the issue. (still waiting for technician to do this...)
How do I install my Panasonic KXTGA401 phone?
The KX-TGA401 is a handset for specific Panasonic cordless telephone systems. Connecting the handset requires registering (pairing) it with the base and if the base can support another handset. First make sure that the base is plugged into an active phone line (land line) and that the power adapter is plugged in and working properly. Charge the handset before attempting the registration process.
Then make sure that the phone system is in standby (no calls). Press and hold the Locator button on the base for about 5 seconds (wait until the tone sounds). If all of the handsets that are already registered ring, press and release the Locator button and then press and hold it again. Once you hear the registration tone (some models), place the new handset in the charger on the base. Wait for the long beep and the registered symbol to appear.
If the not registered symbol appears, try registering by using the handset menu. Press Menu # 1 3 0 (the key below 9 and individual number keys) on the handset. Press and hold the locator button until you hear the registration tone as above. Then press Select and Save on the handset within 90 seconds of hearing the registration tone. Wait for the handset and base to complete the registration process. You'll hear a long beep.
The first registration method is given in the manual for the handset, http://help.panasonic.ca/viewing/ALL/KX-TGA401/OI/TGA401_PNQX2390ZA/TGA401_PNQX2390ZA.pdf. The second is from the page 31 of the manual for the KX-TG653x (KX-TG6531 base) system, ftp://ftp.panasonic.com/telephone/om/kx-tg6511_mul_om.pdf . The KX-TGA401 handset works with other bases as well. You may want to check the manual for your phone system in case there are differences. Other compatible phone systems are the KX-TG401x, KX-TG403x, and KX-TG651x.
I hope this helps.
(I make sure that the land line is active by checking for dial tone with an old corded phone.)
How to change the ringtone
http://service.us.panasonic.com/OPERMANPDF/KXTGA101.PDF
When you get to ringer settings press select, then using the arrow keys scroll to ringer tone, choose one of the tones or melodies then select save and then select off to get out of the menu you should have chosen a new ring tone.
1helpful
2answers
How can we change the ringtone on Panasonic KX-T7730 phone?
You don't. Panasonic analog system phones have one ring tone. You can change the cadence (single double or triple) ring from outside calls, but not the tone.
Carl
ON PHONE KX-T7420 NEED TO CHANGE HANDSET RINGTONE . WE HAVE FOUR IN ONE OFFICE AND ALL SAQME RINGTONE.
The phone has 8 ring tones. From the idle phone, press PROGRAM and dial 99. Press the intercom or a CO line button TWICE and dial 2-8 on the keypad (1 is already default). When you're satisfied with the tone, press STORE. You have to do this for each line and the intercom you want to change and you need to do this at each phone. Pick up the handset and drop it back down to exit programming.
Carl
Panasonic kx-tga101s -- problem regarding making conference call - this is very much helpfull. But i have weird problem, i did call 1 person, and then i asked the person to hold and i made the other call....
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones.
12helpful
2answers
Ring tones on KX-T7433
Wow, this is your lucky day :-)
From each phone, press PROGRAM 99 and the INTERCOM or CO buttons TWICE, then dial 1-8 and STORE. (default is 2). You can now make each line and intercom different, or each phone (up to 8) different. After you finish with each phone, just pick up and drop the handset back into the cradle to end programming.
The feature is called Ringing Tone Selection.
Carl
27helpful
4answers
How to change the incomming ring tone on panasonic kx-t7630
Oh hell... you must be going nuts if its the ring tone I think you're stuck with. I loath the manual that comes with this system so here it is in English:
  • Press 'Prog'
  • Press 'Intercom' twice
  • Now you can either go through the different ring tones by pressing 'SEL' on the LCD screen or using the Up and Down keys on the circular pad on the bottom right of the phone.
  • Once you have the tone you like click on 'Enter'
  • Pick up handset and hangup to complete the process.
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
