Question about Gateway M280E
How do I install a keyboard in a Gateway M280E Tablet? (Directions with pictures a plus, but not absolutely needed.)
    New Friend:
Power off and remove battery. Remove 2 screws on back cover marked with a K. Open display, gently pry off long thin silver panel between display and keyboard. With fingers at top of keyboard, pull up and flip top over toward ypu, then lay flat and upside down. Disconnect flat cable and remove the keyboard. Reverse steps to replace.
Posted on Dec 28, 2010
I own a gateway M280 convertible laptop designed for windows xp, tablet pc edition.I tried installing windows xp sp2 but it didnt find any hard disks installed on my system.i finally got another os called...
if your installing windows 7 it will have all the touch screen drivers and such already built in, just a matter of enabling then in your control panel
Feb 28, 2011 | Gateway M280E
Broken swivel hinge on Gateway m280e laptop.
not sure about documentation - but for parts you might try dakotapcwarehouse.com - my company has found parts for a lot of its older gateway laptops there
Jun 03, 2010 | Gateway M280E
M280E (41891001) Tablet PC: the screen is very dark, cannot adjust brightness...
hp tablet compaq tc4200: the screen is very dark. cannot adjust in control panel, it's greyed out,
May 16, 2010 | Gateway M280E
Install new hard drive m280e
~er~ what do you wanna to say ? how to install new hard drive?
if yes,you can reference the article :Illustrated how to replace a laptop hard drive
hope it can help you
Jan 13, 2010 | Gateway M280E
How to set sensitivity on digital pen gateway m280e
http://support.gateway.com/s/Mobile/TabletPC/3501440/3501440faq33.shtml
try it out once..
Oct 18, 2009 | Gateway M275 Tablet PC
Hi i like to install xp profecianal on my laptop m280e i have on it xp7 tablet ther any probleme to install xp profecianal please responce
XP professional will not work on that unit. The OS will install and work properly but you will lose many of your tablet functions. You have to have the tablet pc edition for all comonents to function. You would not gain anything by going to Pro, and your Windows or Microsoft update will keep your current tablet pc edition updated properly.
Aug 18, 2009 | Gateway M280E
When I make a selection using the mouse I used to be able to tap on the mouse pad for this Gateway Tablet PC, now I have to use the right-click selection.
If you go to the Gateway computers support site there may be updated drivers or software for your tablet pc that allows tweaking the mouse pad adjustments (with more refinement possible than was on your tablet originally).
It is also possible that the pad is experiencing wear / mechanical problems.
Jul 16, 2009 | Gateway M280E
Operating system
I've seen a Microsoft articl telling you how to do it, but it's really technical and complex. Here's the link to a google search I did, check out some of these articles.
http://www.google.com/search?hl=en&q=transfer+windows+xp+to+new+hard+drive&aq=2&oq=transfer+windows+xp&aqi=g10
May 29, 2009 | Gateway M280E
Pen won't click
Go to the Command Prompt form there try to format . When its format its work.
Sep 19, 2008 | Gateway M280E
Problem with pen/software on Gateway M280E
First install the anti virus software then update the software then scan your computer after scan try again. if it cant work format your computer.
Sep 03, 2007 | Gateway M280E
Gateway M280E Logo
206 people viewed this question
Top Gateway Tablets & eReaders Experts
Ekse
rongg
Bill Boyd
Are you a Gateway Tablet and eReader Expert? Answer questions, earn points and help others
