Question about LG LHD45EL Dehumidifier
The unit keeps turning on but there is no water collected
Posted by suzynormandi on
Anonymous
    New Friend:
The unit keeps turning on but theres no water
Posted on May 06, 2010
D. Floyd Kolb
  • LG Master
  • 43,501 Answers
Here is a tip that will help you with basic trouble shooting..
http://www.fixya.com/support/r3877515-dehumidifier_problems_dehumidifier
heatman101
Posted on Apr 28, 2010
Not pulling water out of the air
The humidity level you have the unit set on may be to high. Keep in mind, a higher number is not what the dehumidifier will remove. It's what it will maintain. Lowering the percentage to say 45% or minimum if you don't have a LED readout, should cause the unit to turn ON and collect water in the bucket. Also, be sure that the air intake filter is clean and not clogged.
If you want to do an in home test, put the humidifier in the bathroom, turn on a hot shower, set the unit to it's lowest setting and as you walk out, close the door. DO NOT use the exhaust fan in the bathroom. After about 15 - 20 minutes return to the bathroom, turn the shower OFF and check the unit's water collection bucket. If you see any water in it, it's working as it should.
Hope this helped you solve the problem. Please let me know. Thanks.
May 17, 2011 | Danby DDR600R Silhouette Dehumidifier
Motor runs, but dehumidifier does not collect water
Keep in mind, that a dehumidifier only draws humidity from the air, if the level of humidity is higher than what the controls are set on. The fan running, may be the automatic defrost cycle, that defrost the coils, if they become frosted over. The defrost cycle, depending on the unit and how is was designed, can last any where from 15 minutes up to 45 minutes.
Also, a dirty air intake filter makes the unit strain to keep up and can't take in moisture as it should. So, if you haven't cleaned the filter on a regular basis, not is the time to do so. And while your at it, clean the cooling coils too.
The easiest and best way to test a dehumidifier at home, to see if it's working properly. Is to place it in the bathroom and turn the shower ON and don't operate the bathroom's exhaust fan. Set the humidity level low (45%), turn the unit ON and close the door when you leave. Wait 30 to 40 minutes and check the water collection bucket. If there's water in it, it's working as it should.
Hope this helped you to solve the problem. Please let me know.
May 03, 2011 | Whirlpool Dehumidifiers
Freezing problwm; very small amount of water was collected.
Here is a tip that I wrote that will help you understand why and what you can do with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Apr 27, 2011 | Soleus CFM-40 Dehumidifier
It is not producing water, it runs but no water is collecting in pan.
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again.
Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue.
This situation will have to be addressed by a qualified technician.
Take care.
Aug 19, 2010 | Whirlpool AD25BBK Dehumidifier
My dehumidifier is running but not collecting any water. I have cleaned the filter and it still wont collect water. Is it broken?
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Good luck.
Aug 15, 2010 | LG Dehumidifiers
My Maytag Model number M7DH65B2A is not collecting water
Take care.
Aug 12, 2010 | Maytag M7DH65B2A Dehumidifier
My dehumidifier has not, does not collect any water. HELP !
Take care.
Aug 10, 2010 | Amcor AHD45 Dehumidifier
Unit not collecting water
Good luck.
May 15, 2010 | Soleus CFM-40 Dehumidifier
Dehumidifier won't start
there should be a trip switch that is not resetting remove the bucket and find the switch. gently lift it up and try again
Aug 13, 2009 | Amana D545M Dehumidifier
Dehumidifier does not collect water.
My unit does not collect water any more. It was fine until I lent it to my brother in law and it was returned damaged. Do you know how to fix this
Dec 06, 2006 | Kenmore 54501 Dehumidifier
LG LHD45EL Dehumidifier Logo
99 people viewed this question
Top LG Dehumidifiers Experts
jdthefixer
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
