Question about Mitsubishi WS-65313 65" Rear Projection HDTV
After power failure, TV will not turn on
The Mitsubishi WS 65869 or 65909 (don't know which for sure but I think operation is identical) won't restart after power failure. The green timer light is on a fast blink and the power button on both the TV and the remote control are ineffective. Pushing the reset will momentarily turn off the green timer light, but when you release reset, fast blink resumes. Any ideas?
Pop
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
Sorry but u have bad dm3 board
Posted on Apr 21, 2010
6ya staff
SOURCE:
Green timer light won't stop flashing on mitsubishi ws 73711.
the green light blinking is normal if set has been unplugged--when set is plugged back it should blink for about 70 seconds and then go out--then you can try to turn it on---it is the DM unit inside the set booting up.
If the light just blinks and never stops you have likely bad caps in the DM unit---there are kits available for that.
The other possible reason is that so called reset switch may be bad--fairly easy way to find that out and it is more common than you would think, let me know if you have questions.
SD TECH
May 06, 2012 | Mitsubishi WS-73711 73" Rear Projection...
Mitsubishi tv ws-55859 after power failure green timer light won't quit blinking
there is problem withe your power board.check fuse,cap,if faulty replace with good one.
Oct 16, 2010 | Televison & Video
After a power failrue . my 65" Mitsubishi keeps flshing green light. I cannot turn it on. Reset couple times, did not help.
Replace the DM capacitors. That will often happen after a power failure, as the capacitors will be bad and the set will continue to operate fine untill the power is lost, then they can no longer charge due to their being weak so the timer led will blink repeatedly because the DM cannot complete the boot sequence untill the capacitors charge.
Jan 22, 2010 | Mitsubishi WS-65712 65" Rear Projection...
Have a mitsubshi model no vs-5017s tv turns on sometimes.sometimes just clicks goes off when trying to turn on.i think it might be the timer but dont know how to reset.help
If it is the timer, the timer would be found in your menu, and it would have a minute timer showing on the screen. Otherwise you proabably have the all-to-common power supply failure. It can be tested with voltmeter. You can test the capacitors in the power supply with a capacitor tester. These capacitors due tend to go way more quickly now days.
Sep 09, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi-ws55859 power failure flashing timer green light
the capacitors on the DM need to be replaced. Very easy repair you can get the repair kit at this link which is for your model it contains the replacement capacitors and step by step insturctions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Apr 03, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Blinking light no power
Same here Once I plug the tv WS-55513 to 120 volts the green blinking timer blinks endlessly
Jun 24, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi blinking light
sure can if you still need help let me know.
May 13, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
check the pico fuses on the reverse side of the DM , Just check them in circuit for continuity. let me know how you make out, and if you need any more advice lert me know
Mar 18, 2008 | Mitsubishi WS-48513 48" Rear Projection...
Mitsubishi WS-65313 65" Rear Projection HDTV Logo
541 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
