Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis washer model 110.2709 - Clean washer light is on and machine beeps, after we run the clean washer cycle the light and beep does not clear out. I can't get the washer to run a wash cycle without turning it off then on and quickly starting a cycle. It will run cycle but it still beeps through out wash cycle and cannot pause cycle without having to start all over again.
Posted by aandbfire on
Anonymous
    New Friend:
  • 33 Answers
Ok this is easy there was a defect on all of them don't worry easy and free fix I want you to call this # (800) 659-7026 they will get your info and send someone out to replace control board. Free. In mean time I want you to unplug washer because it's dc motor it still has juice so hit power then stop tell the lights don't come on plug back in and enjoy the temp fix tell they come out to fix it. Don't worry I sell them and I have one and it is still a great washer it was just the first one out of it's kind so it had flaws but sears is taking care of it's customers.
Posted on Apr 29, 2010
2 Related Answers
Anonymous
  • 261 Answers
SOURCE: Kenmore Oasis Elite---110-27086601
This error only shows in diagnostic mode, with power off choose any buttons except stop and power, press in intervals 5 seconds on and 5 seconds off until 88 appears and all light light up. If the user panel is faulted F 2 will flash in the display, press the same button you used to start diagnostics to jump to the next error code and once through 88 will flash and diagnostics will start. Sometimes once F2 flashes and the machine has not been repaired it will stick at that mode.
Posted on Sep 12, 2008
Simplycrap
  • 13 Answers
SOURCE: Kenmore Elite Oasis 2709 water level problem
Remember- your kenmore elite is not like other washers, it super efficient and uses very little water compared to the older models, even though it does not look like it has enough water in it to fo a load of laundry- it actually does everything Bout this machine is efficient , it uses less water , electricity, and soap, it even spins at an extremely high rat of speed to get more water out of the clothes so your drier doesnt have to run do long.
Posted on Oct 27, 2011
Have kenmore oasis washer - beeps when not running or on...when i try to run a load, it defaults to "clean washer" setting - thinking, ok...it needs to be cleaned...i run the clean washer...
F02 means that there is a problem with your user interface control board. A button could be stuck on the board. Try pushing all the buttons to make sure that none is stuck. Most likely u will need to replace your user interface.
Jul 15, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Intermittent beeping and now after you set the
This symptom indicates a stuck key on the user interface control board.
Replacing this control board would most likely fix this type of problem.
The part number for the user interface for this model is 8564374.
You can order this part from SearsPartsDirect.com, RepairClinic.com, PartSelect.com etc.
The procedure for replacing this control board is shown in the images below.
Before buying any parts I suggest you access the interface ribbon and disconnect it and then connect it back and see if there is any improvement.
You might also remove the interface from the console and check the console for any stuck buttons.
Remember to unplug the washer first.
http://media.fotki.com/1_p,wkgbsdrbswtkdqwxgtqsskgwtqkq,vi/ksgtwdgrtxkrrffsdss/1/1303472/5961857/image29464img-or.jpg
http://media.fotki.com/1_p,sqrbbsbrrbwrbdtxgtqsskgwtqkq,vi/kbqtdwdswxkbswddwbg/1/1303472/5961857/image23056img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!
Mar 31, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
3 quick beeps during cycle if you can get it to stay in a cycle
MY KENMORE OASIS HE IS DRIVING ME CRAZY! THE CYCLE SIGNAL CONTINUES TO BEEP AT LEAST 25 TIMES, STOPS FOR MAYBE 20 SECONDS, THEN BEEPS AGAIN ABOUT 25 TIMES. THE WASHER WORKS GREAT, BUT IT WILL NOT STOP BEEPING! HELP!!!!!
Sep 13, 2008 | Kenmore Oasis HE 27062 Top Load Washer
F2 and beeping
The F2 error is the user control board gone south on you, a new board will fix the machine, as always do you own your home and does the insurance cover appliances?
Sep 05, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Clean Cycle
I had the same problem. After unplugging and plugged it in several times, I got it to switch to a wash cycle. But now it beeps every 20 seconds.
Aug 23, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Panel Beeping and F2 error code.
IT SOUNDS LIKE YOU GUYS HAVE A BAD KEYPAD/USER INTERFACE. LOOK IN THE SERVICE MANUAL FOR THIS TOPIC AND FOLLOW THE TEST:
ACTIVATION OF CONSOLE AND INDICATORS
DIAGNOSTIC TEST MODE
[email protected]
Aug 05, 2008 | Kenmore Oasis HE 27087
Kenmore oasis top-loader problem
You might try using the clean washer cycle, works on mine. I use the full amount of bleach allowed. No more smell...now if I can just get that pesky beeping noise to stop...
Dec 05, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
Michael Thomas
Michael Thomas
Paul Carew
Lawrence Oravetz
