Question about Ranger TR-696F SSB CB Radio
Signal meter not working. is there a quick fix, for this problem
Posted by George Barto on
Melanie Rogers
    Champion:
  • 219 Answers
Is the meter good?
Posted on May 01, 2010
1999 Dodge Grande Caravan. Left signal light works sometimes and sometimes it want. How to fix?
Basic automotive electrical testing with a volt meter is how to fix ! Find a wiring diagram and componet location chart - connector's wire harness , power and ground locations etc.... Diagnosing Turn Signal Problems http://www.bbbind.com/free_tsb.html Could be the turn signal switch , lose connection somewhere . Ground problem .
Feb 14, 2017 | Dodge Cars & Trucks
How do i fix the tachometer?
you have an in cluster factory engine tachometer (RPM)?
the tacho is meter in the cluster and does not use speedo parts or its cable.
its just a meter that needs power, ground and spark tacho signals
if all 3 are good, the meter is bad. period.
the tacho signal goes to the ignition coil minus lug, and will good, as engine runs. so... wires bad, to tacho or tacho bad.
ever price a new one? or even used? $100 used?
you willing to pay that much for just a factory tacho?
there is NO speedo cable. this old 93 is electronic, (rare on most 93 cars made, toy is advanced)
here is the proof, amazing how books dont lie....
there is a speed sensor.
the tacho and speedo use the same power and ground
leaving just one wire,r-g red-green RPM sig. pin 5 of cluster
an is SPARK primary sig. so if only tacho is dead.
then the tacho is bad, or that pin 5 wire is dead.
got you to just 2 possibles.
Jan 26, 2015 | 1993 Toyota Corolla
2007 Mini Cooper convertible, stereo signal got worse and now can't listen to the radio, other functions still work. Have changed aerial and still no change? Any clues??
some sort of bad connection inside the radios socket
or bad coax
check the antenna with an ohm meter
to see if the coax is shorted out
and also that there is continutity between the center pin of the coax radio plug and the antenna
you can demount the radio and stick a bit of wire in as a quick test
if you get the signal then its something coax related
if not its something to do with the front end of the radios reciever circuit
and you need a radio engineer that fixes car radios and cb etc
they will make it work for sure
i could in ten mins flat ...possibly a transistor has failed
or a bad connection as it comes and goes ...
Dec 04, 2014 | 2007 Mini Cooper Convertible
I have a 820S kenwood I purchased it from a pawn shop in California, I could not get the S meter to sense the incoming signal / I played with the connectors and the S meter started working. Well it quit...
What is your ham radio call sign? I rarely look at the s-meter. If you can hear the other station, you probably can work them. The s-meter is valuable when turning your directional antenna to locate the transmitting station better. If your antenna won't turn, call him anyway.
Jul 08, 2014 | Radio Communications
How to fix cobra 1000 gtl Powers up,meters stuck, no rx just static, All lights work, A mic will Key the on the air light,
have you checked the voltages inside the radio?If you have to much or to little it will not work properly.
Jan 19, 2014 | Cobra 2000 Gtl / 1000 Rf Pwr / Signal...
Tx rx
the problem you now have is probably going to cost you more money to fix than the radio is worth. Could be a quick simple fix or you could be at it for hours trying to fix it. you will need a scope, frequency counter,watt meter, modulation meter, signal generator, volt meter,distortion meter,and a service manual from
www.cbtricks.com
Jun 18, 2013 | Galaxy Radios DX-33HML 40-Channels Base CB...
How does the moisture meter work?
EHow says: Electrical power is easily conducted through a moist or wet environment. When wood fibers contain moisture it can also conduct an electrical signal or voltage. This allows the moisture meter to act as a signal generator. The signal generator will output a small voltage into the wood fibers. The small voltage is typically supplied by a battery. The moisture meter contains an internal circuitry much like an ohmmeter. The ohmmeter reads the amount of resistance that an electrical circuit may employ in conducting electricity.
Read more: How Does a Moisture Meter Work? ' eHow.com http://www.ehow.com/how-does_4924697_moisture-meter-work.html#ixzz2JRaS12Xt
Jan 30, 2013 | Measuring Tools & Sensors
The wipers,signal lights,gas meter,cigarettedoesnt work
Wipers, Signals, Cigarette is most probably because of failed fuses. Please check the fuse box. because all you have listed are not related to each other they are not likely to fail at the same time. Gas meter i doubt whether it is because of fuse or not. Gas meter failures or wrong indications are common problem in mercedeses. So first better to check the fuse box. it may fix all those problems.
Oct 20, 2010 | Mercedes-Benz ML350 Cars & Trucks
My turn signals won't come on. My hazard lights work. Fuses are fine. What next?
despite ur hazards working the relay that controls ur signals may still be faulty. alternatively the indicator 'stalk' itself maybe at fault. start with the relay, if its expensive, pick up a couple from ur local srapyard, odds are 1 in 2 or 3 will work. ur fault is something and nothing. if u can use a multi meter to read voltage its a quickly found fault.
Jun 17, 2010 | 1998 Ford Expedition
I have a 2006 boulevard c50 and the rear marker lights aren't working the front markers are still working, signal lights all work as well as the hazards but yet i cant get the markers to light up even...
a 12 volt test lamp, or a muti-meter, are very handy tools for finding the problems like you have. to check if you have power going to the rear markers? You can trace your wires better with one of these tools, and usually fix the problem quickly. also check all your fuses in the fuse box, mabey there is a fuse for the rear markers?
May 18, 2010 | 2007 Suzuki Boulevard
Ranger TR-696F SSB CB Radio Logo
63 people viewed this question
Top Ranger Radio Communications Experts
normis101
John L radiodude365
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
