Question about Hitachi 55HDS69 55 in. Plasma Television
Hitachi Plasma TV 55HDT79 that is turning on and off and back on
We have a Hitachi Plasma TV 42HDT79 that is turning on but keeps shutting itself off. This repeats itself over and over. Any thoughts?
Posted by satcbt on
Anonymous
Go Setup in the menu. At the bottom you will see Reset The Software when power is turned off. Switch this to No.
Posted on Jan 22, 2011
  • mshaul Jul 15, 2011
    I have the exact same problem. I can't get to setup as it cycles too fast.
Hitachi 42hdt79
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Aug 06, 2014 | Hitachi 42HDT79 42 in. Plasma Television
TENGO PROBLEMA CON UNA PLASMA HITACHI 42HDT79 SOLO SE VEN RAYAS DE COLORES VERTICALES SI HAY SONIDO Y ABAJO DE LAS RAYAS SE VE LA IMAGEN
Hola que tal oye porque cuando prendo mi tele Hitachi 42hdt79 se pone en standby se escucha todo pero no se mira nada ni le puedo cambiar de canal ni subir volumen
Aug 30, 2012 | Hitachi 42HDT79 42 in. Plasma Television
I have a hitachi 42hdt79 and yesterday the power just went off. the power button on the tv does not power it on nor does the remote. just dead.
The internal fuse, if you are lucky, may have gone. It is situated before the on off switch and mains filtering circuit board.
Jan 01, 2011 | Hitachi 42HDT79 42 in. Plasma Television
I have a hitachi p50x01au plasma and I was just watching tv and it turned off by itself.I tried to turn it back on and all I get is a green blinking light.Do I need to call a technician?
you need to unplug power cord from back of tv and let it set for awhile then plug back into the back of the tv i also have a plasma and it sometimes does that also
Jan 06, 2010 | Hitachi 42HDT79 42 in. Plasma Television
42hdt79 Hitachi TV will not power up. Cord is good TV is dead ??
Try the button on the front bottom, under the power button on the front.
Apr 05, 2009 | Hitachi 42HDT79 42 in. Plasma Television
Hitachi 42hdt79 tv guide on screen with not remember tv guide lis
Mine did/does the same,,,while in standby it also did/does produce a clicking sound intermitently.....now Pic and sound cycles on/off every 10 seconds or so. Intestingly...I could go on....but whats the point........JUNK Hitachi says "to bad" 26 months old and $800 to fix. Buy another brand........
Feb 22, 2009 | Hitachi 42HDT79 42 in. Plasma Television
Hitachi brand and model
NO...mine broke after just two years $800 to fix
Dec 25, 2008 | Hitachi 42HDT79 42 in. Plasma Television
Hitachi 55HDS69 55 in. Plasma Television Logo
1,539 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
