Manual Removal:
1. Press Ctrl+Alt+Del on keyboard to stop process associated to "XP Home
Security 2011?. When Windows Task Manager opens, go to Processes Tab
and find and end the following process:
(random characters).exe
2. You need to update your installed antivirus application to have the latest database.
3. Thoroughly scan the computer and any detected threats must be
removed. If removal is prohibited, it is best to quarantine the infected
item. Manually locating and deleting of malicious files should also be
performed. Please see files below that are related to XP Home Security
2011 Virus.
4. Registry entries created by XP Home Security 2011 must also be remove
from the Windows system. Please refer below for entries associated to
the rogue program.
[how to edit registry]
5. Exit registry editor.
6. Get rid of XP Home Security 2011 start-up entry by going to
Start >
Run, type
msconfig on the "Open" dialog box. A windows containing System Configuration Utility will be launched. Go to
Startup tab and uncheck the following Start-up item(s):
7. Click
Apply and restart the computer.
XP Home Security 2011 Removal Tool:
In order to completely remove the threat from a computer, it is best to download and run
Malwarebytes Anti-Malware.
Sometimes, Trojans will block the downloading and installation of MBAM.
If this happens, download it from a clean computer and rename the
executable file before executing on the infected computer.
Using Portable SuperAntiSpyware:
To thoroughly clean a computer, it is best to do a separate scan of
another security program so that other infected files not detected by
anti-virus application can be remove as well. Download and run
SuperAntiSpyware Portable Scanner.
Did you run the full scan? and what malware did it pick up?
