Dometic Rooftop RV Air Conditioner Logo
Posted on Apr 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to identify the btu of rooftop AC unit
I have Dometic rooftop AC model 57915541 but can't tell what size the unit is.
thanks
dan
Anonymous
Level 2:
New Friend:
  • Expert 59 Answers
  • Posted on Apr 21, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
59
Questions
0
Helped
30372
Points
119
ANY # DIVISABLE BY 12. MODEL HAS  12-24-30-36-40-48-54-60 12 1 TON 24 2 TON 30 2 1/2 36  3 TON 36.00 BTU 40 3 1/2 48 4 TON 48.00 BTU 54  4 1/2 60 5 TON   60.000 BTU
What size ac 59516 331
15,000 BTU. Here's a link for you. http://www.dometic.com/FileOrganizer/1-international/Operation%20&%20Installation%20Manuals/Air%20Conditioners%20-%20Vehicles/Duo-Therm-HP_installation_EN.pdf
Is this a thermostat problem or system failure?
it sounds like no communication from stat to board. cable connections
What model number Dometic AC unit to add to RV?
You can use Dometic Brisk Air II model for your RV. It has 13,500 BTU capacity. I used this air conditioning unit for last 2 years on my RV truck. If you want to know more about this unit, you can check this link. https://coolingmyrv.com/
I have a dometic rv unit 15000 btu what is the amp draw?
For an RV 15000 BTU air conditioner the size being maximum for 115 volts ac you will need to have a independent circuit breaker for it only and rated at 20 amps. The average amps depends on serveral factors like actual supply voltage somtimes 110 to 120 volts and wire size and length feeding the air conditioner. To answer your question the average Amps will be near 13 Amps. Click Here=>
Dometic RV Air Conditioner Installation Manual and Specifications
Click here for a photo of the Electrical Spects.=>
Dometic_RV_Air_Conditioner_Electrical_Specifications
If you have any questions I will be here to answer them for you, Thanks, Sea Breeze
What type freon for 1998 newmar mountainaire 15000 btu ac unit
Early years were R-22 but the best way to double check would be to contact manufacturer with model and serial number for confirmation.
( dometicusa.com ) for dometic products, or ( http://www.rvcomfort.com/rvp/tech_info/manuals.php ) for Coleman.
I have a 13500 btu ac dometic penguin model on pan that is old and would like to replace with 15000 btu ac of any other manufacturer or another dometic what are my options ..I do not have ducts and do not...
Your choices are another Dometic or a Coleman
I prefer the Coleman But the amount of extra cooling you will get by stepping up to a 15K unit will probability not be worth the added cost
3helpful
Btu for dometic 59516.531
59516 is a Brisk Air 15000 BTU.
Thanks for using Fixya
Jerry
Top Dometic Heating & Cooling Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
