Question about Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
Temp Alarm going off and not very cold inside.
This morning our freezer alarm was going off and the inside was not cold enough to keep the food frozen. I came home today and it was still going off. We bought it used off of craigslist and just turned it on last week to prepare for our food. We had no problems with food not inside of i, but now that it is stocked full, we are experiencing problems.
Posted by alextharp on
Raz Mataz
  • 389 Answers
I think you should see if the circulation fan is working inside. Sometimes they need a little push and some WD 40 let me know. I might have another idea. The Raz Shack
Posted on Apr 21, 2010
My high temp alarm has been on all day
the warming up will be because the unit is not operational and the door hasn't been opened
call a service technician and check for a failed start/run capacitor for the compressor
the high temp alarm indicates that the food is in danger of spoiling
Sep 06, 2015 | Frigidaire White Frost Free Upright...
Temp alarm keeps buzzing but inside temp is still cold
dear sir/madam
make sure tempreture sensor is on correct position after that restart your freezer if its same problem i mean buzzing temperature alarm then it,s need to change .
hope answer the question
thank you
please vote!
Aug 20, 2010 | Kenmore Freezers
Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Feb 05, 2010 | Freezers
The temp alarm keeps sounding,I turn it off and in about 12 hrs it alarms again. The food is frozen and inside still cold
It sounds like the sensor has gone bad. You can either replace it or disable it. Of course if you disable it, obviously you lose that feature. If you want to replace it, you can get the part at kenmore.com or possible W.W. Grainger or APCO.
Aug 05, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
The alarm button is flashing
-18c is about 0 F. it shold be cold enough to freeze you know what.
you might want to turn the tempture up a little.
Apr 01, 2009 | Bosch 9.1 cu. ft. / 258 liter Upright...
Temp alarm on freezer alarming.
that's the same problem i incurred, i replaced the thermostat and the fan. seems to be working fine.
Dec 03, 2008 | Kenmore Freezer 14.1 cu. ft. Upright...
Its keeps peeping
Hello twins49
Welcome to Fixya,
You said, your Frigidaire freezer 17 cu. ft. , it keeps buzzing or peeping
The alarm may be malfunctioning or it may be warning you of low temperature.
You can go to any hard ware store and buy a refrigerator thermometer and ask them if it can go into a freezer too!It can, But ask anyway!
If it is cold enough then it is a faulty alarm going off.
Your freezer may be equipped with an alarm.
Here is some information that may help you find it and turn it off if you wish
Temp Alarm (audible only or audible with warning light)
This feature is designed to provide a warning of possible malfunction. If the
temperature of the food rises to a level unsafe for long-term storage, the buzzer will
sound. The red light will also glow on models so equipped. The Temp Alarm feature
operates on household electricity. If power fails, the alarm will not perform. An ON/
OFF switch allows you to deactivate the Temp Alarm when not wanted. The freezer
is shipped with Temp Alarm in the OFF position. After freezer has run approximately
4 hours, the red light, if equipped, will go off. Then you may activate the Temp Alarm
without the alarm sounding.
Press the ON switch to activate the Temp Alarm. To deactivate, press the OFF switch.
If the alarm sounds, be sure freezer is properly leveled, and the door closes freely, and
seals properly. If you suspect a technical malfunction, call an authorized servicer
immediately.
Let me no what you find.
Huuum
Please remember to leave a rating before you leave
Aug 26, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Temp alarm going off
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting Need to check the temp to make sure its cold enough.. thats what that alarm is for
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
220 people viewed this question
Top Kenmore Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
