Refrigerators Logo
Posted on Apr 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to know the interior cu. ft. measurement of my Kenmore top freezer fridge - Model #363.9762821 and serial # L62749257, purchased in 1996. Thanks for your help!
Anonymous
Level 3:
  • Master 712 Answers
  • Posted on Apr 21, 2010
Anonymous
Master
Level 3:
Answers
712
Questions
0
Helped
194675
Points
2097
You can just measure it simply using a tape. The ones provided by the company differ from the actual volume.
How many cubic feet is my Kenmore model 253.54362409 refrigerator please?
Total Refrigerator Capacity 26.70 cu ft Measure Freezer Fresh Food Total Capacity Cubic Feet 7.66 cu ft 19.02 cu ft 26.70 cu ft Liters
How many cubic feet is my Kenmore Fridge Model 596.72003014? The sticker on the inside of the fridge does not have the cubic feet and I can't find it anywhere online or in the manual.
The third digit after the period usually indicates the capacity of newer Kenmore refrigerators. Since this is a bottom freezer with two door refigerator, it's probably a 20 cu. ft. model. If you have the original documentation, the energy efficiency label will have the capacity listed.
I hope this helps. To check, use a measuring tape to get the height, depth and width. Multiply the values together. If you measured in inches, divide by 1728 (12 x 12 x 12) to convert cu. in. to cu. ft.
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
1helpful
What is the cubic ft measurement of a Kenmore side by side fridge, model # 57572791, serial # SH2448358
25.0 Cu. Ft.
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=GSS25QGPBB
The freezer works well but the fridgedoes not get cold enough
all the fridge does is blow cold air from the freezer down into the fridge section so if the freezer is working then either the evap fan isn't working or the air ducts are frozen up.first thing open the freezer door,you should hear the fan blowing,if not the fan motor could be bad,if it is blowing,touch the back inside wall of the freezer,is there any ice or like snow on it,if so you have a defrost problem,one more thing to check,open the fridge door,look under the bottom draws,is there any water there? or any water dripping into the fridge section from the freezer,if so you have a blocked drain and the air ducts are frozen.let me know what you find,send the model number off of the fridge,open the fridge door and look on the left side up near the ceiling,you should see a tag with the model and serial numbers just send the model
I am looking for the dimension and capacity of fridge 69852990
Measure Exterior Height & Width and Depth for Dimension.
Interior Space = Then, Measure all open accessible area inside the fridge and add the two together, following the formula of H+W+L Freezer and H+W+L Refrigerator,add together and BAM ya got cubic inches.= Square inches, then divide by 1,728 (the number of cubic inches in a foot (3) Cubed.
Example 1: 60 inches tall, 42 inches wide, 30 inches deep = 75600/1728 = 43.75 Cubic Foot AREA
Example 2: fREEZER dIMS = 24 DEEP x 18 HIGH x 36 WIDE =15552/1728 is 9 CuFt. Refridgerator 36 wide, 36 high 28 deep = 36,288/1728 = 21 CuFt. + 9 CuFt. = 30 Cubic Foot Capacity.
By the Math Wiz RUDY :)
1helpful
Fridge/freezer not getting cold
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
4helpful
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
My freezer in my refrigerator keeps over freezing...
you may have a gasket leak letting hot air in check around the door
Kenmore refrigerator 25364150400 fridge won't get
check your evaporator coil in freezer it is froze up ,need to check to make sure defrost timer is working. Also check drain line.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
