The Kenwood KAC-7252 and KAC-9104D are both great amps, but they have different strengths and weaknesses. The KAC-7252 is a 5-channel amp that can output 75 watts per channel at 4 ohms. It also has a built-in crossover and time alignment, which can be helpful for getting the most out of your woofers. The KAC-9104D is a 4-channel amp that can output 100 watts per channel at 4 ohms. It also has a built-in subwoofer output, which can be used to power a separate subwoofer.
If you are looking for an amp that can power all of your speakers, the KAC-7252 is a great option. It is also a good choice if you want an amp with built-in crossover and time alignment. However, if you are looking for an amp that can power a subwoofer, the KAC-9104D is a better choice. It is also a good choice if you want an amp with more power output.
Ultimately, the best amp for you will depend on your specific needs and budget. If you are not sure which amp is right for you, it is always a good idea to consult with a professional car audio installer.
Here is a more detailed comparison of the two amps:
Kenwood KAC-7252
- 5-channel amp
- 75 watts per channel at 4 ohms
- Built-in crossover and time alignment
- MSRP: $399
Kenwood KAC-9104D
- 4-channel amp
- 100 watts per channel at 4 ohms
- Built-in subwoofer output
- MSRP: $499
I hope this helps!
