Question about UPM Programmable Wall Switch Timer
Instructions for upm etw350 indoor timer - UPM Programmable Wall Switch Timer
Posted by bushmonkie on
Anonymous
Etw 350 programmable timer PDF instructions
http://waterheatertimer.org/UPM-etw350.pdf
Posted on Sep 26, 2010
Upm etw350
Copy following link to identify timer and download manual:
http://waterheatertimer.org/UPM-timers-and-manuals.html#ETW
ETW can be used to replace 3-way switch.
3-way switching has 2 switches. Timer can replace one switch or the other switch, but not both.
The remaining 3-way switch must be rewired as shown in manual. What the remaining 3-way switch does is reverse timer programming, so programmed ON times become OFF times, and OFF times become ON times.
Add a comment as needed.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 19, 2013 | UPM Programmable Wall Switch Timer
LIGHTS FLASHING WITH ETW350
If this is new installation, the wiring is incorrect.
If this is old installation, try resetting timer.
Copy following link to see how to wire single-pole timer.
http://waterheatertimer.org/How-to-wire-timers.html
Aug 04, 2012 | UPM Programmable Wall Switch Timer
How to programme UPM Model ETl30
More information is needed to find manual.
ET130 timer appears to have 6 buttons with 3 buttons on each row.
http://hkm888.com/upm-marketing-et130-indoor-programmable-timer-reviews.html
Review options below:
1) Add a comment and describe timer buttons in detail so I can match buttons with known timers.
2) Open following links and check if manuals for ET525, ET420C, ET420 might have same button and programming relationship.
http://waterheatertimer.org/UPM-timers-and-manuals.html#ET420C
http://waterheatertimer.org/UPM-timers-and-manuals.html#ET130
Add a comment please
Oct 02, 2011 | UPM Indoor Electronic Programmable Plug-In...
Want to know how to set the times "on" "off". Timer is a bit older. Front of the timer has "set' "cd" rnd."
1) Open following links to identify same-similar timer, and download possible manual:
http://waterheatertimer.org/images/ETW350-buttons-200.jpg
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/images/Woods-49556-400.jpg
2) If timer does not appear on links above, take in-focus photo and post on flickr, and then add a comment with link to photo so I can see the timer for possible identification.
Aug 08, 2011 | UPM Programmable Wall Switch Timer
I am having a problem setting the UPM ETW350 timer, can't seem to have it go off at a certain time. What do I do about the countdown? IS that what I press to go to the time to shut it off?
You posted under UPM 350 programmable timer
Manuals for all UPM timers are missing key explanations, despite the lengthy manual.
I think there are 3 things to look for:
1) Program1 is ON and program2 is OFF and program3 is ON etc.
2) When setting days, be sure that ON and OFF are set for same days so there are no conflicting programs.
3) Timer gives three modes: Countdown and Random and Programming. Countdown is for a bath fan when you want to turn on fan with push of button and have timer turn off fan automatically after the countdown expires. Do not use countdown or random functions when you want timer to perform ordinary on-off functions.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail or phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Dec 14, 2010 | UPM Programmable Wall Switch Timer
I also am having trouble with this timer. I've got the program set for when I want it to go on but can't figure out how to put in the time I want it to stop. I don't understand where the countdown timer...
ETW350 is programmable timer that offers 3 different timer
functions: Program, countdown and random.
Timer has 20 different settings.
UPM site is not available recently, but UPM timers are still being sold.
Operation manual is not very clear how to program ON and OFF times.
http://waterheatertimer.org/pdf/UPM-etw350.pdf
That being said, usually with programmable timers, you program ON time. And then program OFF time.
I do not own this timer so I can't test ETW350 like I've tested other timers.
I think the way this timer works, is program1 is ON.
And program2 is OFF.
Again, manual is not CLEAR about ON and OFF times.
Following instructions assume timer is wired correctly, timer is set for current time, and you want to set 'timer' function and not 'random' function.
Here's how to set program1.
Press arrow buttons until 1 shows in display. This is program1.
Press Set button.
Select day for program1 ON using arrow keys
Press Set button.
Select hour for program1 ON using arrow keys.
Press Set button.
Select minute for program1 ON using arrow keys.
Press Set button.
Use arrow keys until 2 appears on display. This is program2.
I believe program2 is for OFF times.
Set program2 using same steps above.
Be careful to match ON and OFF days ... for example ON 7pm Monday and OFF 9pm Friday will keep lights on from Mon through FRI.
Conflicts in programming will cause timer not to work. For example program1 ON 7pm Monday, program2 OFF 9pm Monday ... but programs3-4 say opposite times.
Make a schedule of program times before starting to avoid conflicts.
Try steps above and test fire that timer, and then add a comment.
Nov 24, 2010 | UPM Programmable Wall Switch Timer
How do we set the time to stop on a UPM ETW350? I know how to set the time to start but i do not know how to set the time to stop. Thank you
In wall timers and manuals are shown on following link.
http://waterheatertimer.org/Programmable.html#ETW
ETW350 manual:
Select from 3 different functions:
1) 24-hour Programmable
2) Countdown timer function so lights turn off after period of time
3) Random function so lights turn on randomly and house looks lived-in
I am not going to write out the steps because they show in the manual.
But a specific part of the manual might be confusing.
So add a comment and I will help until we will get the timer working.
Nov 20, 2010 | UPM Programmable Wall Switch Timer
I need the instructions for a UPM Model 100 indoor programmable timer...
UPM100?
Do you mean UPM RTC100 remote control timer set?
Smarthome usually posts manuals with their products:
See if this is your product:
http://www.smarthome.com/2046/Programmable-Receptacle-Timer/p.aspx
pdf manual
http://www.smarthome.com/manuals/2046.pdf
add a comment if this is not your timer
Nov 20, 2010 | UPM Indoor Electronic Programmable Plug-In...
I have lost the instruction sheet for operation. Can't remember how to set it. Model ET160
ET160 is a UPM plug-in type digital timer
http://waterheatertimer.org/pdf/UPM-ET160-wall-timer.pdf
If you have problems with specific part of manual, add a comment and I will answer
Oct 30, 2010 | UPM Indoor Electronic Programmable Plug-In...
UPM Programmable Wall Switch Timer Logo
1,558 people viewed this question
Top UPM Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you an UPM Hardware and Accessory Expert? Answer questions, earn points and help others
