Paula, You may have to sand vanity all down so stain can be applied to cover water staining, if water stains/damage does not sand out easily. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." How to Get Water Stains Off Wood
Normally a washer does not cause a staining problem, but If something inside the washer has rusted, it could. I would check your water tank. Drain water from the drain cock at the bottom of the tank, and see how dirty it is. If it is dirty, you need to drain the water until it is almost clear.
that is your timing cover gasket. sending a picture of a 1996 ford 5.0 that need a bad leak see the yellow stain that was anti freezing at the timing cover
When you see this starting to develope it is usually indicative of the screen delaminating. The different layers of the lcd may be failing and the picture will start to get more and more destorted. There is no fix except screen replacement.
Basically there are holes in the base of the AC that allow water (condensation) to run out, that may be plugged, and usually you can tell by how much run-off you have on your roof, and the stain will also guide you to where to poke with wire to unclog. Best way to be sure is to take all the screws out around base of cover & lift cover off. Just watch for bees, or wasps before you do, they like to nest in there..If all unplugged & running out good but water still coming in trailer, then you may have a cracked drain pan.
Tried lots of suggestions to no avail. Tried a USED, dried out Scotch Brite Cook Top pad on the scrubber handle with Heavy Duty Fantastick sprayed on the pad. Scrubbed the drip marks at the bottom and wiped away to see if it was "scratching" or marri8ng the finish. Nope, but IT WAS taking the water marks off. So I did a bit more and checked again. Working great with no problems for the finish. Cleaned the whole watermark area. Rinsed of with wet cloth. Let it dry and then used my usual stainless cleaner, buffed to shine and walked away to post this. :> My refrig is an Aman too but I read other problem sites and it is common with stainless steel refrigs
