My washing machine is leaking underneath. It is not the intake or drain hoses on the back. I dried the floor and ran a new wash and it was leaking as it filled. It was dripping from the front right corner, but also more water was coming from underneath. Any tips on what this might be before I open it up. I'd like to know at least where to start looking. The washer is 4 yrs old.
Sounds like your water valve is leaking. If you shut the water valves off at the wall and it stops then for sure your valve is leaking. The leaking from under the washer could be coming from the pump leaking, overloading, hoses leaking on the connections or a tub seal. I would check the pump first, just tip it back a little and see if you feel water on the pump, it's right up front. This washer is very easy to work on.
If your washing machine is leaking,
don't rush out to buy a new one just yet. Sometimes simple repairs to
the machine can fix the leaks saving you hundreds of dollars and days of
shopping for and installing a new one. Luckily, you don't have to be a
master electrician to do repairs. These steps will walk you through the
basics of fixing a washing machine. Bellow are Instructions on how to solve the problem of leaking washing machine
Look at the floor drain to make
sure it isn't clogged. Sometimes it's not even the washing machine, but
the drain causing those puddles of water on the floor. Unclogging the
drain can be an easy and quick fix.
Inspect the hoses for leaks or
wear and tear in certain spots. Filling the washing machine may help
identify any leaks or faulty hoses. If hoses are worn, replace them with
non-burst stainless steel mesh hoses.
Check the fittings of the
existing hoses to the faucet fixtures and on the back of the washing
machine. Sometimes a loose connection is the cause for the leaks.
Tighten couplings and hose clamps if necessary to fix the leaks.
Replace internal washers inside
of the hoses if not replacing the entire hose. Something as small as a
rubber gasket can create a lot of water damage. Use a screwdriver to pop
the worn washer out and replace it. Repeat replacing washers on the
other end of the hose.
5
Examine internal components by
opening the cabinet and starting the fill cycle to see if anything is
leaking internally. Calcium deposits and rust may be evident around
areas that have leaks.
6
Use hose clamp pliers to remove
any corroded spring clamps and replace them with new ones. Make sure the
hose is still intact underneath the old clamp. If not, remove the
internal hose and take it to an appliance repair center to find the
correct replacement part.
If
you are having a problem with your washing machine i.e leaking, don't rush out to buy a new one just
yet. Sometimes simple repairs to the machine can fix the leaks saving
you hundreds of dollars and days of shopping for and installing a new
one. Luckily, you don't have to be a master electrician to do repairs.
These steps will walk you through the basics of fixing a washing
machine. Instructions
Look
at the floor drain to make sure it isn't clogged. Sometimes it's not
even the washing machine, but the drain causing those puddles of water
on the floor. Unclogging the drain can be an easy and quick fix.
Inspect
the hoses for leaks or wear and tear in certain spots. Filling the
washing machine may help identify any leaks or faulty hoses. If hoses
are worn, replace them with non-burst stainless steel mesh hoses.
Check
the fittings of the existing hoses to the faucet fixtures and on the
back of the washing machine. Sometimes a loose connection is the cause
for the leaks. Tighten couplings and hose clamps if necessary to fix
the leaks.
Replace
internal washers inside of the hoses if not replacing the entire hose.
Something as small as a rubber gasket can create a lot of water damage.
Use a screwdriver to pop the worn washer out and replace it. Repeat
replacing washers on the other end of the hose.
Examine
internal components by opening the cabinet and starting the fill cycle
to see if anything is leaking internally. Calcium deposits and rust may
be evident around areas that have leaks.
Use
hose clamp pliers to remove any corroded spring clamps and replace them
with new ones. Make sure the hose is still intact underneath the old
clamp. If not, remove the internal hose and take it to an appliance
repair center to find the correct replacement part.
Good luck and thank you and thanks for using fixya.
Check your drain. It might be slow and overflowing. Fill the washer and unplug it overnight and see if you get any water on the floor. Take the back off and do a load . Look for leaks. I have a manual and repair photos HERE
The drain hose must be at least level with the top of the actual tub in the washer. The water pump is only bad if it is leaking. If it is leaking from the front you either have a cracked outer tub, but it sounds like your water pump, easy to change out just get the model # and order it through an appliance parts distributor. The cost is about 40 to 50 bucks. good luck!
First make sure that you can obtain a new hose either from the maker or pattern part supplier
Once you have that part take the current hose off the back of the machine and lay it down into a bucket to drain off all of the water
Take any clips that secure the hose to the back panel and then remove that.
Follow the hose back to the pump
Lay the machine forward onto a strong surface and put something underneath it to prevent it falling on you
Remove the clip holding the outlet hose onto the pump and fit the new one , stand the machine upright and our some water into the drum by hand check for leaks
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
IN FRONT? IF SO, PULL IT OUT AWAY FROM WALL 2 FEET AND LEAN BACK AGAINST WALL. LOOK UNDER MACHINE IN FRONT, PUMP HAS 2 HOSES ATTACHED. IF LEAKING THROUGH PUMP, REPLACE THE PUMP.
