Question about Ohm PIONEER 12" DUAL VOICE COIL 1000W 4 Car Speaker
My sub keeps popping when working?
I have a twin 100w pioneer subwoofer. it keeps popping when working whats wrong with it?
Posted by palky_sport on
Graeme Ross
  • 1,512 Answers
Hi there
If this happens on high levels, popping from your subs generally relates to the cone being over exerted and reaching the physical limits of the cone travel, or the amp is approaching its limits resulting in clipping and producing square wave peaks on transients This sort of problem can generally be tuned out of a system by careful adjustment of EQ and drive levels. If the system has been working fine to date, and this is a new problem that has just started, then you may have a failing sub.
regards robotek
Posted on Apr 20, 2010
Help me with a subwoofer circuit
sub-woofer circuit Michael, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
100W Subwoofer Amplifier Circuit Diagram Working and Applications
Subwoofer Filter Circuit
22 Watt Car Subwoofer Amplifier Circuit Diagram
subwoofer circuit Google Search
Jun 03, 2016 | Audio Players & Recorders
WHAT SIZE AND TYPE BOX DO I USE FOR ONE PIONEER TS-W304C SUBWOOFER
You have a lot of choices for this. First, unless you are tuning the sub to a specific frequency you have options. You didn't specify the size of sub so it's difficult to say specifically, but if it's a 12 inch sub, you need about 1.5 to 2 cubic feet. Of course the performance of the sub depends on the music you listen to. If you listen to rock, pop, classical, or country, I recommend a sealed box. A sealed box gives you better control over your sub. The air acts as a cusion and decreases the return time of the cone to rest position. This gives you tighter bass. If you listen to rap or hip hop, I recommend a ported enclosure. This type of enclosure allows for more cone excursion, thus allowing the sub to recreate lower frequencies. Hope this helps.
Aug 12, 2011 | Pioneer TS-W304C Car Subwoofer
I have a pioneer home theater HTZ585 DVD system. Since yesterday, i get 'SUB COM' message displayed (blinking) and nothing seems to work anymore. Any suggestions?
I can't find that message in the manual but I would guess it's trying to tell you something is wrong going out to the subwoofer. Trace the wiring. If you don't see anything wrong, disconnect the sub and see if the message disappears or changes.
Apr 30, 2011 | Pioneer 740 DV Home Theater System System
My jamo sub 200 & pioneer vsx517 receiver is not working properly
What do you mean that it sometimes doesn't work? It doesn't power on automatically?
Check settings of your receiver - if it has subwoofer output enables and if low frequencies from all channels are directed also to the SUB. By default only the LFE channel (.1) of 5.1 signal input is fed to the subwoofer. So Sub will work in this case only when you listen to 5.1 signal (DVD movie for example), but for radio or stereo music, only front speakers are used. By configuring this bass redirect, you can use subwoofer for all signal types.
Feb 08, 2010 | Jamo SUB 200 Subwoofer
Powered subwoofer keeps blowing its fuse
The amp is blown. You need to get it in for service. No telling exactlly what is wrong untill it is opened. 215-736-8055
Jan 15, 2010 | Onkyo Bass Reflex Powered Subwoofer...
Subwoofer Turns Off when volume is turned up
check your earth from the amp i had same prob and the vibration broke earth connection once secured it was fine
Aug 24, 2009 | Pioneer TS-SWX310 Car Subwoofer
I have the pioneer sub and a sony 600watt 4
it has a detector that kicks in it will usually shut off your amp and it keeps you from blowing your amp the speaker may have to much power and amp may not push it it will start to protect itself
Jun 07, 2009 | Pioneer TS-W307D4 Car Subwoofer
I have a Pioneer VSX-35TX receiver when connected to the subwoofer there is no sound questions on what I am doing wrong.
Set front speakers for small and make sure sub is turned on in setup mode. If Front speakers are sent to large I believe the only time sub will work is with Dolby Digital Lfe signals. If sub is turned off of course it will never work.
Feb 10, 2008 | Audio Players & Recorders
Car Audio & Video Logo
176 people viewed this question
Top Ohm Car Audio & Video Experts
Harrie
Steve Pack
Steve Pack
brian williams
Are you an Ohm Car Audio and Video Expert? Answer questions, earn points and help others
